I believe that the head cover is held on by the spark plug tube nuts. There may also be some bolts from the timing belt cover. When reinstalling they spark plug nuts are only torqued to 17 ft lbs. I believe they take a 30 mm socket. New gasket and plug grommets are recommended. Often you can just torque the spark plug nuts down to 17 ft lbs to take care of a minor leak. While you are in this area clean out your pcv valve.
Page EG1-16 for the 5SFE engine on line manual.
Kep
