HVAC Problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-09-2008, 09:31 PM   #1 (permalink)
Ballin Ass Camry
stewart591's Avatar
View stewart591's Photo Gallery
4th Generation HVAC Problem
ok so the thing that you flip to recycle or fresh air cord broke and now i cant pick fresh air setting... what can i do?
stewart591 is offline   Reply With Quote
Old 01-09-2008, 10:04 PM   #2 (permalink)
'00 V-6 Camry's Avatar
View '00 V-6 Camry's Photo Gallery
???? is it a switch or a push button, because i have a 2000 and mine went out and i just replaced a fuse and voila! it work sohope that helped ... yeah mines a push button by the way
FloridaBoy lost in North Dakota
'00 V-6 Camry is offline   Reply With Quote
Old 01-09-2008, 10:53 PM   #3 (permalink)
Ballin Ass Camry
stewart591's Avatar
naaa if you pull the whole ac control panel ull see a cord and that broke somehow ill put up a pic tomorrow
Old 01-10-2008, 10:55 AM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I believe that you are referring to the "air mix damper control". The only mention that I find for it is in the "body" section of the on-line manual at BO-115. I never could find the section for the ac/heater blend box. I expect that you can get a replacement. If you get a used cable lubricate it with speedometer cable lube before you install it.
Kep
2002 Tacoma 4x4 TRD Differential or Transmission problem? sailingceleste 1st Generation (1995.5–2004) 15 07-26-2007 12:14 PM
problem with 5th gear (manual) afan Camry & Solara Lounge 6 11-21-2005 10:15 PM
vacuum leak problem...also electrical problem related. afyouthbrigade Camry & Solara Lounge 5 11-03-2005 01:45 PM
QUICK SHIFTER/UNDER PANEL PROBLEM!! & DVD NAVIGATION??!! Rocness81 1st Generation (2003-2008) 6 12-09-2004 10:27 AM
Help! Auto Tranny problem Lilwhite Celica Forum 3 02-14-2004 01:33 PM
