Adjusting Headlight? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2008, 10:23 AM   #1 (permalink)
I'm a NEWB, so help me!
trd_racer87's Avatar
View trd_racer87's Photo Gallery
Would anybody please tell me how to adjust my headlights please? I can't seem to find it..
I993 T0Y0T@ C@MRY \/6 XLE (3VZ-FE)
trd_racer87 is offline   Reply With Quote
Old 01-10-2008, 06:58 PM   #2 (permalink)
Registered User
View tooyoungtoodie's Photo Gallery
on back of the headlights, there is a screw which you can screw it counter clockwise if you want or the other way if you want, and a up and down screw. just look for both of it.
tooyoungtoodie is offline   Reply With Quote
Old 01-10-2008, 09:06 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
There are two adjustment screws. One points up and one points back.
Kep
Old 01-10-2008, 11:28 PM   #4 (permalink)
Toyota Technician
View bigdaddymak20's Photo Gallery
4th Generation
Great pic of the adjusters. Best way is to pull up next to a wall on level ground and make the adjustments. We had an expensive tool to do this in the dealer and most of use just used a wall and works just fine. Just make sure you dont point the drivers side too much to the left or youll get flashed all the time even with the low beams on.
bigdaddymak20 is offline   Reply With Quote
Old 01-11-2008, 09:26 AM   #5 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
On level surface, mark center of lights on wall ( I use tape and you can make a wall of board or cardboard, etc.) when about 3' away. Then back straight up to about 25' away and adjust beams to match marks. JMHO, but that's how I was told to do it.
Dave's is offline   Reply With Quote
Old 01-11-2008, 03:46 PM   #6 (permalink)
THANK YOU ALL FOR THE INFORMATION, really, I appreciate it, thanks so much.
DIY: taking apart headlights (56k: 20 low resolution pictures. you decide) JustAnotherAsian 5th & 6th Generation (2002-2006 & 2007-2011) 59 04-14-2010 05:14 PM
[UPDATED w/ more photos!!] Gen 3 new cystral headlight housing arrived (w/ pics) bowen 3rd & 4th Generation (1992–1996 & 1997–2001) 62 10-09-2006 11:01 PM
Seperating 02-04 Camry headlights italia490 5th & 6th Generation (2002-2006 & 2007-2011) 1 12-17-2004 12:18 PM
trouble adjusting headlight... i think its broken ryuji16 Camry & Solara Lounge 13 03-26-2004 10:13 PM
my driver side headlight is really crooked TypeZer0 Camry & Solara Lounge 6 09-09-2003 09:15 AM
