help where to find wires - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2008, 08:07 PM   #1 (permalink)
View syang's Photo Gallery
3rd Generation help where to find wires
i'm trying to install a dvd indash unit into my little bros camry 93 xle v6.
unit is kenwood kvt-617dvd
i have to questions on where to find the pink wire (reverse sensor wire)
and the green wire (parking sensor wire)
any help will be truly appreciated.
Yang
syang is offline   Reply With Quote
Old 01-11-2008, 09:16 AM   #2 (permalink)
Heat's Avatar
View Heat's Photo Gallery
I have no idea, but you might try the file "be.pdf" from this site:
http://www.**********s.com/camry/
It's the repair manual.
Heat is offline   Reply With Quote
Old 01-11-2008, 09:56 AM   #3 (permalink)
If you will download the Gen 3 repair manual ... wherever it is currently available ... and go to the wiring diagram section ... Located on p. 83, you will see a pink wire and a light green wire in the vicinity of the Vehicle Speed Sensor block ... right hand side, about half way down .... If these wires are the ones which you want to find, then look for connector IP2 on p. 44, in the location diagram ... under passenger side dash.
Is what you are looking for ...?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
gen2 91 camry damaged spark plug wires desertstrm2000 1st & 2nd Generation (1983–1986 & 1987-1991) 5 03-02-2005 02:42 PM
spark plug wires bowlofturtle General Discussion 4 08-31-2004 04:37 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
