2000 Camry XLE remote - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2008, 06:48 PM   #1 (permalink)
View mmo_prez's Photo Gallery
2 questions if I may
1st
my security system seems to be troubled.
its the factory system that came with the car.
seems that all 3 remotes dont want to work. If I hold it button down for an extended period it will lock the doors but the the security light stays solid for a bit . this just happened and as I said we have 3 remotes.
also need to hold it down to unlock .
2nd should my doors be locking when the car is engaged in drive ? we have always heard this noice once speed reaches about 3 mph sound like a relay or something .. the dealer said it is the light sensor coming on but if I let it sit at night and the lights come on automatically then the sensor should be on but it still makes this noise .
any help would be great
Thanx
Prez
mmo_prez is offline   Reply With Quote
Old 01-11-2008, 07:01 PM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
Have you checked or tried changing the battery?
2007 Camry 2.4L 5M
Old 01-11-2008, 07:05 PM   #3 (permalink)
car battery or remote battery ?
Well car battery is fine ..
but as for remote battery no I have not .. 3 remotes not working ? all batteries dead at the same time ? one of the remotes it attached to the valet key so it never gets used .
Thanx
Prez
Old 01-11-2008, 10:10 PM   #4 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Have you ever changed the remote battery? If not, do that first. It's a cheap thing to rule out. I generally change the remote battery out every few years max - or when I notice I have to start holding the button down and going close to the car until it arms/disarms. On a fresh battery it works from a LONG distance and takes one short button press to arm/disarm the system.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
Old 01-11-2008, 10:15 PM   #5 (permalink)
Thanx
Prez
Yes, the remote battery.
2007 Camry 2.4L 5M
Old 01-11-2008, 10:47 PM   #6 (permalink)
will try the remote battery .. but I figured with all 3 remotes not working that would not be it ... one of them has a 6 month old battery.
Even the red led security light isnt working like normal .. used to always flash .. now after I get it to arm it stays red solid for awhile .
But it does work better close to the car.
Thanx
Prez
Old 01-12-2008, 11:30 AM   #7 (permalink)
tried new battery no good ..
Just got off the phone with the dealer we purchased from and he is no help either ..
How do I tell what system I have ?
is it RS3000 or secure Key ?
thanx
Prez
Old 01-12-2008, 11:44 AM   #8 (permalink)
On my 98, the factory system is called SecuriKey+.
There is a detailed instructional brochure that describes the various options which are enabled by various means.
The red led to the left of the steering column is actually a push button.
If you turn the ignition to on, and then push the button, so that it is in the outer position, the alarm should be activated, and should blink after you exit and close the doors. Do you observe this particular action?
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 01-12-2008, 12:03 PM   #9 (permalink)
no I have only a red led inside the instrument cluster.
Old 01-12-2008, 04:57 PM   #10 (permalink)
well go figure.. I guess maybe because of the weather we have been having .. for a few days it was very warm with rain and then dropped below freezing maybe something got frozen .. today all is fine ..
ahh well thanx for all your help guyz
Prez
History of the Toyota Camry Ratko Camry & Solara Lounge 54 01-13-2012 08:42 PM
Program New Key 2000 Camry Xle V6 2000XLEV6 3rd & 4th Generation (1992–1996 & 1997–2001) 7 11-20-2007 11:56 AM
2001 Camry XLE V6 Canadian version: JBL stereo? Tubbyc 3rd & 4th Generation (1992–1996 & 1997–2001) 1 04-26-2006 05:37 AM
Having trouble with alarm system in 2000 Camry LE JavaFanatic 3rd & 4th Generation (1992–1996 & 1997–2001) 9 03-12-2005 12:16 PM
CAI For 2000 Camry XLE V6? aleks77 3rd & 4th Generation (1992–1996 & 1997–2001) 12 05-29-2004 09:41 PM
