car wont start - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2008, 08:08 PM   #1 (permalink)
View blazinxpk's Photo Gallery
car wont start
car: 1994 toyota camry I4 AT 154,xxx
i was on vacation for 2 weeks and the camry was sitting in the garage the whole time. when i came back to move the camry out of the garage it started up fine. this was on saturday. now monday comes and the cars been sitting on the driveway since saturday, i get in the car and turn the key and nothing happens. the lights in the gauge cluster turn on and the clock thats located on top of the a.c vents. when i turned the key the clock dimmed to where you cant see it anymore and when i turn the key back to the point where you can pull it out the clock comes back.(some sort of powerdrain?)
i tried cleaning the battery terminals and checked the wires, i also tried recharging the battery incase if it was low.
now what could be causing this problem? can someone please tell me what size battery should be used for this car for some reason the battery that i have just looks to small for the car. also can this be a problem with the starter?
forgot to mention that on monday when i started the car at first there was this clicking noise, but after a few turns of the key that clicking sound went away. now theres just no sound at all just a turn a of the key and no noise at all.
any help will be appreciated
1994 camry LE I4 154,xxx
1996 avalon xls V6 aka garage queen 61,xxx
blazinxpk is offline   Reply With Quote
Old 01-11-2008, 09:22 PM   #2 (permalink)
Toy_Dreamer's Avatar
View Toy_Dreamer's Photo Gallery
you might need a new starter... They are not cheap, but before you get to excited replace the battery. It might not be holding its charge.
The battery size is group size 35. You can check this size for the number on your battery.
1998 Camry XLE | Black | Custom Halo Lights | Fogs | Infinity Kappa front speakers | Infinity Reference Sub | SRI Secret Weapon R...
Toy_Dreamer is offline   Reply With Quote
Old 01-12-2008, 08:23 PM   #3 (permalink)
well i showed the car to my mechanic today and he said its most likely the starter. had to tow the car to his shop. hopefully im a going to have the car fixed in a few days. thanks for the help Toy_Dreamer
Old 01-12-2008, 09:39 PM   #4 (permalink)
hey no problem. good luck with that fix blazinxpk!
Old 01-13-2008, 11:50 AM   #5 (permalink)
Gameroom cash: $303055
"forgot to mention that on monday when i started the car at first there was this clicking noise, but after a few turns of the key that clicking sound went away. now theres just no sound at all just a turn a of the key and no noise at all."
1 click indicates a problem with the contacts in the starter's solenoid. Do a search for "starter contacts" and read up on the problem as this has been covered many times. Multiple rapic clicks indicates a problem with the battery itself, corroded connections at the battery or the starter, or a problem with the charging syytem (alternator or loose alternator belt) not properly recharging the battery.
Mike
Old 01-14-2008, 01:11 AM   #6 (permalink)
thanks guy. the problem was the starter so i got that fixed and also for some reason the mechanic said that my alarm was acting as a kill switch in some way. so he rewired that and now the car works fine.
Old 01-14-2008, 02:12 PM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I would encourage you to get him to write down (or tell you and you write down) exactly what he did on the alarm system. These systems are very temperamental and you may find it very helpful down the road if you end up having to trouble shoot it again. If the alarm system is working correctly, it is supposed to act as a kill switch when the car is being tampered with.
Kep
MKIV Scam registry bmw5002 Supra Forum 11 07-09-2010 11:59 PM
A few vip camry pics MattSWE Camry & Solara Lounge 95 07-29-2008 09:43 AM
the car will not start SlowRolla37 8th Generation (1998-2002) 2 11-22-2007 06:45 PM
My car won't start, help! sxv20 Camry & Solara Lounge 1 10-19-2005 03:46 PM
