testing fuel pressure - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2008, 12:26 PM   #1 (permalink)
View burkej62's Photo Gallery
Anyone know how to test the fuel pressure on a 94 camry? I know some cars have a shrader valve in the fuel line but I see none.
burkej62 is offline   Reply With Quote
Old 01-12-2008, 02:09 PM   #2 (permalink)
Gameroom cash: $422950
View Stillrunning's Photo Gallery
There is no Schrader. Actron has a fuel pressure kit that includes a banjo fitting that installs on the fuel filter but it is not meant for permanent installation. I adapted the Actron -4 Schrader fitting on the inline tester in the kit to a "T" fitting with hose fittings and installed it inline in the fuel line after the filter. I can now test without disconnecting the fuel fittings using the Actron gauge.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 187K
Stillrunning is offline   Reply With Quote
Old 01-13-2008, 10:48 AM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
There is a quick & dirty fuel pump test in the Engine section of the on-line manual at EG1-178. It continues with a precision test if you feel that you need to go further. The Harbor Freight Tool stores here (Houston) are having a sale on their fuel pressure kits (don't know how hard it will be to hook up the Camry banjo fitting). this week.
Kep
How to Turbo the Camry - 5s-fTe tips and information Hamsterman Camry & Solara Lounge 118 09-23-2010 10:43 AM
fuel pressure tester daveO Camry & Solara Lounge 1 09-19-2007 02:36 PM
Fuel pressure, or fuel tank pressure? Rembrant 1st Generation (1995.5–2004) 4 10-14-2006 06:08 PM
85 Celica GTS Fuel Pressure Problem Denis Celica Forum 6 03-16-2006 08:11 PM
New fuel pressure regulator design: Opinions Please synapse Hardcore Tech and Competition 11 08-29-2005 06:51 PM
