The wiper switch is shown on the wiring diagram as one integral part ....
Not sure if it comes apart without tearing it up ...
Maybe just spray it as best you can.
One other observation ... several recent posts have described a problem where the door locks have activated when the wiper switch was moved or activated ...
It could be that the wiper switch connection wires .... as they travel along the steering wheel column... kind of under the dash area, are being rubbed against something.
Just as one more thing to try ... move the wires around under the dash, in the vicinity of the steering wheel column and see if there are any relevant changes ...
Not completely sure, but it looks like the wire which controls the intermittent delay on the wiper motor is
a light blue wire with a yellow stripe .... going from the wiper control switch down the steering column, and eventually going to the wiper motor .... Might be something to locate ... jostle around a little, and see if anything different happens.
Again .... might be advisable to give the wiper control switch a spritz or two with the contact cleaner.
... Was looking through the Body Electrical section of the repair manual ... there should be a diagnostic procedure for the window wiper and washer switch ... not sure what page, just scroll down until you find it.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
