Valvoline MaxLife ATF OK for 94 Camry? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2008, 05:34 PM   #1 (permalink)
View waynearny's Photo Gallery
USA Valvoline MaxLife ATF OK for 94 Camry?
I've got a 94 Camry with 153,000 miles on it. It's been in the family for about 6 years, and the ATF has never been changed. I'm doing it now and am about to put Valvoline MaxLive ATF in it. Any problem with that? The product says it's for vehicles with > 75K miles on it, and it list Toyota Type T, T-III, and T-IV as fluids it can replace.
I'm also just dropping the pan, draining, cleaning the filter and replacing filter and pan using a new Toyota gasket. Any potential problems here?
Thanks. Been working on mostly air-cooled older stick shift vehicles, so I'm new to the ATF business! Thanks!! Wayne Arny, Galesville, MD
waynearny is offline   Reply With Quote
Old 01-12-2008, 06:13 PM   #2 (permalink)
View wahed3001's Photo Gallery
That Camry takes Dextron II ATF. If the bottle says Mercon or Dextron II/III type then it's okay to put it in. The one you got is for the newer Toyota vehicles. I Personally use Valvoline Dex/Merc
ATF which works just fine.
There's no problem in cleaning the pan and filter. I doubt you'll find anything in the filter/screen (I didn't!) but if you do take the screen out replace the cork o-ring around it with a new one ($2 at the dealer) as the old one should be crumbly and break apart. One more thing: don't forget to replace the two magnets on the pan as they are designed to catch metal fragments small enough to pass through the screen. Put the magnets back at the same points on the pan as before. If you want an 'upgrade' you can replace those weak ceramic magnets with the new super strong neodymium magnets. But make sure you get the ones with higher operating temperatures (over 100 deg C) as the cheaper ones may start loosing their magnetism at the ATF operating temperatures. I got my high temperature magnets here: http://www.kjmagnetics.com/proddetai...=D82SH&cat=167
wahed3001 is offline   Reply With Quote
Old 01-12-2008, 09:57 PM   #3 (permalink)
V6LE_CAMRY's Avatar
View V6LE_CAMRY's Photo Gallery
yea you can use that, i've acutully have been using that valvoline atf in my 96 for two years now
V6LE_CAMRY is offline   Reply With Quote
Old 01-12-2008, 11:04 PM   #4 (permalink)
Thanks! I'm putting it in tonight!
Old 01-12-2008, 11:08 PM   #5 (permalink)
Many thanks for the advice. This time I had to reuse the old magnets, but I will get new ones for the next time, and fortunately, the cork seal for the screen was in decent shape, so I reused it. It's amazing what the books and the dealer don't tell you! I cleaned everything as well as I could, put in the new seal, reinstalled the screen and the pan, tightened it all down, and replaced the fluid. It all worked well, but now I am better prepared when I do it again! Thanks, also again! Wayne Arny, Galesville, MD
Old 01-13-2008, 11:02 AM   #6 (permalink)
Good Job!
Old 06-17-2009, 01:06 PM   #7 (permalink)
Waheguru
jatt lehmber's Avatar
View jatt lehmber's Photo Gallery
yo can u explain to me what filter screen is, the cork o ring, and explain where the hell the magnets are located, sorry for bothering u but i seem not to know too much about trasmissions
jatt lehmber is offline   Reply With Quote
Old 06-17-2009, 02:05 PM   #8 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
yes, MaxLife ATF is compatible with almost everything ... theres a few exceptions, but nothing youd have to worry about if youre posting in this section
thats what mine had in it
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 06-17-2009, 02:21 PM   #9 (permalink)
View Camry LE 94's Photo Gallery
3rd Generation
DIY: 5S-FE Transmission Fluid & Strainer Replacement Procedure
check this link out. most of your questions will be explained in this thread.
Camry LE 94 is offline   Reply With Quote
Old 06-17-2009, 08:11 PM   #10 (permalink)
Gameroom cash: $556930
View JohnGD's Photo Gallery
No, you don't have to use "new magnets". Just replace "old magnets" back to their proper locations on the pan.
You should consider getting a Fram ATF kit next time (~$15-20). It has a cork rubber pan gasket, a new strainer and the strainer gasket.
You can also try the Walmart SuperTech ATF compatible with Dexron II/III. Works fine and economically. I think SuperTech Mercon V is also compatible with Dexron II/III (but not all are). Mercon V is a synthtic blend. Good deal.
Old 06-17-2009, 08:19 PM   #11 (permalink)
The 2.2L Camry uses Aisin 140 series transmission. Takes Fram filter kit #FT1169 (replaces FT1137). Rockauto has wholesale closeout for $12.39+shipping. Good deal. Normally they're $20.79.
Here is a picture of the "strainer", you called "filter screen" with cork gasket:
http://www.rockauto.com/catalog/moreinfo.php?pk=55970
The magnets are around the pick up port. Just make sure when you place them back you don't block the fluid flow. You can see the rectangular pick up port in this picture:
http://198.208.187.182/internet/Part...cpartnbr=TF328
Old 06-17-2009, 08:19 PM   #12 (permalink)
BTW, the kit should also contain a large pan gasket. NOt shown in the pictures except the ATE one.
Old 06-17-2009, 08:21 PM   #13 (permalink)
Here is a Beck Arnley one with the pan gasket picture. They should all have it.
http://www.rockauto.com/catalog/moreinfo.php?pk=478691
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
Fusion marches past Camry! sciguy0504 Camry & Solara Lounge 38 05-04-2006 06:27 AM
using Mobil 1 ATF as Power Steering Fluid for 2002 Camry 2002Camry 5th & 6th Generation (2002-2006 & 2007-2011) 0 05-12-2003 10:10 AM
2003 TOYOTA CAMRY XLE vs. 2003 HONDA ACCORD [NEW].. Macreative 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-15-2002 01:10 PM
TCI ANNOUNCES PRICES OF ALL-NEW 2002 CAMRY - F bondobondo 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-14-2001 12:48 PM
