2000 Camry MPG Issue - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2008, 04:17 AM   #1 (permalink)
View StanCamry's Photo Gallery
I have 2000 Toyota Camry LE 4 cylinders. I have owned the card since Jan 05 / 87K miles. I well-maintained the car since . The car is currently @ 140k miles. Here is what is going on with my car.
- When I bought the car, I used to get 33 MPG on average between Highway/City driving.
Lately (5 month ago), the car MPG went down to 22 MPG. I took the car to mechanic shop, which changed Air/Fuel filters, spark plugs , balanced tires, did some other tune ups . These misc. repairs did not result in any improvements.
- In the last year or so, every time I speed up to 60 MPH or more usually in highway, I either smell burnt rubber or any bad smell.
- Two days ago, check engine light came on; the mechanic put it in computer which indicated problem with catalytic converter.
Any idea what is going on with my car? Are all these issues related? Any suggestions to fix the MPG issue?
Appreciate help in this regard
StanCamry is offline   Reply With Quote
Old 01-13-2008, 11:57 AM   #2 (permalink)
Gameroom cash: $303055
" Two days ago, check engine light came on; the mechanic put it in computer which indicated problem with catalytic converter. "
Did the mechanic then check for a clogged catalytic converter?
Other possible problems that can reduce fuel economy are an out of range coolant temperature sensor, an thermostat stuck in the open position (is the gage on the dash reading normal operating temperature once the car warms up?) or the slightest amount of brake drag.
Mike
Old 01-13-2008, 02:14 PM   #3 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
also any extra weight will decreased.. and if you haver larger diameter after market rims that too will kill the MPG.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
2000 Camry Maintenance Diy Tips cnn 3rd & 4th Generation (1992–1996 & 1997–2001) 8 10-26-2011 11:04 PM
Mpg confusion? kman711 2nd Generation (2005+) 7 10-13-2007 05:36 PM
2002 Camry soft brake issue Ken4 5th & 6th Generation (2002-2006 & 2007-2011) 7 09-08-2007 07:39 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
