Window engine problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2008, 08:32 AM   #1 (permalink)
View Ivar's Photo Gallery
My right passenger window in my Camry 92 is not working, when i measure the volt (V) in the wires that goes to the window engine it show 12,..V to the window engine, but the resistance in the window engine is only 0,7ohm (Ω). Does anyone know how much the ohm in the window engine should be?
Ivar is offline   Reply With Quote
Old 01-13-2008, 09:44 AM   #2 (permalink)
The Camburger
iTrader Score: 6 reviews
View Admiral's Photo Gallery
you may just need a new window regulator. that seems to be a common issue with older cars. I dont know how many ohms it needs but you may wat to try testing it with a window that is working correct;y in your camry. Also, if the door panel has been taken off and put back on, sometimes if the panels have been screwed in too tight, it causes more resistence for the window to go up.
Admiral is offline   Reply With Quote
Old 01-13-2008, 10:32 AM   #3 (permalink)
I am afraid that i have to change the window regulator. But the thing that makes me mad is that i doesn't find one single data sheet on the window motor. I haven't put the door panel on yet, and it still won't go, so i think the motor is dead (R.I.P) But thx for the advises Admiral
Old 01-13-2008, 12:45 PM   #4 (permalink)
If you download the Gen 3 repair manual ... look in the section called Body Electrical.
On p. 87, there is a description of a procedure for testing the window motors.
Basically, you just disconnect the motors and apply 12V from the battery to determine if they will rotate. .... If your motor is working, this section also has some other diagnostic procedures for checking the window switches.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Very interesting... NH05TACOMA 2nd Generation (2005+) 52 04-08-2008 06:20 PM
2004 Camry 2.4L Timing Chain replacement ! norbisko 5th & 6th Generation (2002-2006 & 2007-2011) 15 12-28-2007 11:02 PM
Supra Specs and time frames? glish_dreams Supra Forum 17 04-17-2006 11:14 PM
For All You WINDOW PROBLEM guys. stizick37 Camry & Solara Lounge 6 06-07-2004 11:07 AM
'87 turbodiesel engine problem heigo2 1st & 2nd Generation (1983–1986 & 1987-1991) 3 10-14-2003 01:44 AM
