97 Camry PS PUMP - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-13-2008, 04:06 PM   #1 (permalink)
View bcdeff's Photo Gallery
USA 97 Camry PS PUMP
I replaced my leaking PS pump with a pump that I bought from a junkyard. I rebuilt the pump with a gasket kit, drained the fluid from the lines, removed the leaking pump and installed the rebuilt pump . My steering is worse then it was with the original leaking pump. I placed the Camry on jacks and tried to remove the air from the lines and my arms are tired. Has anybody any advice? Thank you!
BCDEFF
bcdeff is offline   Reply With Quote
Old 01-13-2008, 05:27 PM   #2 (permalink)
There was a recent post on this subject ... getting air out of PS system... As I recall, you put the front end on jack stands, chock the back wheels, and then rotate the steering wheel slowly from one stop to the other.....
See link here .... post #15
http://www.toyotanation.com/forum/t19334.html
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 01-13-2008, 05:39 PM   #3 (permalink)
Unhappy 97 Camry PS PUMP
dc _98_cam thanks for responding. My Camry was on jacks and I must have rotated the steering at least one hundred times. My best friend helped me. I guess I will pull out the pump and compare the original with the rebuilt. Very time consumming to say the least.
bcdeff
'97 Camry Needs Help Beez97Cam 3rd & 4th Generation (1992–1996 & 1997–2001) 5 03-08-2008 03:16 PM
02 Camry Water Pump Replacement rkelachim 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 02:08 AM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
Newbie at Toyota Nation. 97 Camry XLE. moon8613 Introduce Yourself Here 1 06-29-2006 12:51 AM
Low Fuel Indicator Light on '97 Camry? Camry97LE 3rd & 4th Generation (1992–1996 & 1997–2001) 5 05-28-2006 06:09 AM
