Hello all! Seeing as this is my first thread on TN ever, ill give you the history(albeit brief) on my car:
'93 Camry/ Manual Tranny / 3vz-fe
When i bought the car, it had 114,000 miles on it. in the past 6 months, ive put 6,000 more on the car
Although it is mostly stock, i have made a custom intake and have Eibach Springs and bilstein dampers on the way to lower my baby a little bit, to accent the wheels and give me less roll on hard turns(not necessarily in order of precedence).
A week ago i replaced the ORIGINAL plugs and wires(atrocious, i know) with NGK Iridium IX plugs and NGK wires and they improved the quality of the drive a whole lot.
edit:i spoke with the previous owner, they had changed the plugs and wires about 50,000 miles ago. not too bad, but longer than i would have liked
My problem is,(and this only today started happening) when my motor is at operating temperature, in neutral, the RPMs fluctuate from 250-750(sometimes less). If throttle is applied, when released, the RPMs drop almost to a stall and then go back to fluctuating in the above mentioned range. The same thing happens when shifting into neutral to begin deceleration to a stop. it comes really freaking close to stalling then goes back to the fluctuating.
Holy crap i forgot to mention: when im driving, and i go WOT, instead of accelerating, it bogs down. the intake makes more noise accordingly, but it barely if at all speeds up.
What could be the problem? I tried looking for something on TN, and although some threads have similar symptoms, most are for the 1mzfe(i think its called) and none of the fixes seemed like they really applied. ive seen resetting the ECU by disconnecting the battery for 5 minutes(im about to try this), check vacuum hoses(which are fine on my car). what else could it be? A mechanic friend of mine suggests it may be the fuel/air ratio. help!
