A/C outlet not redirecting air - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2008, 06:21 AM   #1 (permalink)
View zymurgist's Photo Gallery
I have a 1994 Camry that I just acquired from my mother. It used to be my dad's car until he passed in June of last year. The car spent all of its life in south Florida, and I drove it up to Maryland this winter. The A/C and heater both work OK in that it blows cold and hot air when requested, but I can't direct air to the feet, defroster, etc. It only comes out the main dash vents no matter how the switch is set.
I have downloaded the Camry PDFs and checked out the switch and servomotor. The servomotor seems to be OK. Although I could hear it operate, I disassembled the dash enough to see it move from position to position whenever I change switch settings. I have to wonder, if the servomotor seems to be working, why doesn't air get redirected? I'm basically trying to get the defroster to work (something that was never an issue in Florida).
zymurgist is offline   Reply With Quote
Old 01-14-2008, 08:28 AM   #2 (permalink)
96 3MZ M/T
chronoti's Avatar
Gameroom cash: $303830
View chronoti's Photo Gallery
the little gate inside of what the servo is turning is probably disconected.
^ and leaving it that way!
Old 01-21-2008, 04:04 PM   #3 (permalink)
Thanks for the advice! I'm going to check it out... when it gets warm enough to work on my car, that is. I'll suffer with the lack of defrost for now.
Ken
1994 Toyota Camry LE
too many other cars!
Old 01-23-2008, 12:08 PM   #4 (permalink)
View bcsbadboys's Photo Gallery
On most vehicles, when the air is not re-directed to the defrost, floor, etc. it's usually the vacuum check valve that needs to be replaced.
Not sure if your Toyota has one, might want to check with your Toyota dealer parts department.
1997 Camry LE 2.2L, 5SFE
160,000
bcsbadboys is offline   Reply With Quote
A/C air flow problem buytamil Camry & Solara Lounge 2 10-10-2007 06:57 AM
Turbo Charger Lwrdtoyota 89-95 Toyota Pickup/Hilux 92 07-26-2007 06:41 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
List of Toyota CEL Codes Marc M 2nd Generation (2005+) 0 03-29-2006 11:01 AM
A/C Air Temp is 56 Degrees eschamp Camry & Solara Lounge 5 07-08-2005 07:51 PM
