Disapearing Coolant - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2008, 10:17 AM   #1 (permalink)
Dude Wheres My Car?
nukem678's Avatar
View nukem678's Photo Gallery
Disapearing Coolant
Hey guys, Every time i do an in depth inspection on my engine i notice that the coolant tank seems to loose like a cup or two of coolant. I just always top it off, but its odd. I have no apearant leak and it does loose very little. I cant figure it out. Its a 4cyl 01 with 60000 miles on it.
I lost my Camry in a parking lot once, Now it will never happen again
nukem678 is offline   Reply With Quote
Old 01-14-2008, 10:28 AM   #2 (permalink)
College owns my wallet...
Venom_5's Avatar
View Venom_5's Photo Gallery
is the coolant reservoir cracked at the top?
do you park in a garage or outside? ... you most likely do have a slow leak, as i had the same problem - and i know a few other guys here have too
Buy My Weapon-R Intake [Here]
http://sck388.mybrute.com
Old 01-14-2008, 10:39 AM   #3 (permalink)
Dude Wheres My Car?
nukem678's Avatar
Everything looks good. I do part outside. I do smell coolant in the engine bay when its hot but i cant locate any type of leak. It just vanishes little by little. It has to be a small leak on a seal someware.
Old 01-14-2008, 11:13 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
check where the hoses meet, as well as look for small leaks in your radiator fins- for small leaks, you will be looking for crystallized coolant, and not actual leaks....quite often it will be missed on the radiator fins
HaHa
Old 01-14-2008, 02:02 PM   #5 (permalink)
One other place to check is the actual water pump itself ....There is a small opening on the outer perimeter, maybe a 1/4" diameter. If the shaft seal on the pump is bad, you will typically find evidence of precipitate or mineral buildup. The actual fluid will have evaporated due to the engine heat. ... Might be a good idea to have a pressure check done on the coolant system .... usually a good way to tell if something is wrong or not.
Requires a gauge type manual pump that attaches with an adapter to the radiator fill neck. ... I bought my own, but most shops will have one.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 01-14-2008, 02:59 PM   #6 (permalink)
View toyomoho's Photo Gallery
As stated check the radiator for leaks. It is possible a radiator pin hole leak only occurs at higher coolant system pressures such as over 10 PSI, with the radiator being hot the coolant evaporates. Also check the plastic air dam below the radiator for signs of coolant as it might collect here.
Old 01-14-2008, 03:24 PM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
The AutoZones around Houston used to have radiator pressure kits that they would loan out. You might check around your area.
Kep
Old 01-14-2008, 07:35 PM   #8 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
+1
mine was cracked and i had coolant leaking/evaporating. look under/around the reservoir to see if there any sign of moistures or leakages.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 01-16-2008, 10:32 AM   #9 (permalink)
Dude Wheres My Car?
nukem678's Avatar
Its so little for now ill let it go untill i see large amounts of coolant disapearing. Thank for the info. It may be a leak in the cooling fins on the rad. The hoses are good.
Fix coolant hose.. replace coolant..then stutter in 1st gear Shogun1011 Pre-88 Toyota Pickup/Hilux 3 08-05-2007 07:02 PM
Coolant Loss/Overheating lusterblade 3rd & 4th Generation (1992–1996 & 1997–2001) 3 05-29-2007 03:16 PM
Coolant loss 2005 Camry I4 winstead22 5th & 6th Generation (2002-2006 & 2007-2011) 2 01-29-2007 05:07 AM
Brand of Coolant stir_fry_boy Camry & Solara Lounge 51 01-12-2006 10:45 AM
1997 Coolant & Differental question.. NorthernIllinoi Archived Corolla threads 6 10-25-2005 09:03 PM
