removing the needle - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-14-2008, 02:41 PM   #1 (permalink)
View J_Phu's Photo Gallery
3rd Generation removing the needle
How would I remove the needles from the guages.?I tried all the diy on google and here but I just can't get it off. Is there a trick or something.
J_Phu is offline   Reply With Quote
Old 01-14-2008, 04:46 PM   #2 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
u dont take them off, if your putting on new faces, you work them on around the needles, pulling on the needles is supposed to be bad...
rebel8ball is offline   Reply With Quote
Old 01-14-2008, 09:07 PM   #3 (permalink)
well it doens't look like there is a way to work around it.
Old 01-14-2008, 10:24 PM   #4 (permalink)
rebel8ball's Avatar
if your putting new faces on they will work around them, its tricky and might take a little work but it will make it, i think on some you might have to unscrew the needle stops but not the needles..
Stuck - removing RH driveaxle from bearing mount awmccready Camry & Solara Lounge 12 04-16-2011 06:53 PM
Removing rear sway bar because of rattle noise. green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 13 02-16-2008 05:53 PM
Erratic Gas Needle 97ava 1st Generation (1995-1999) 2 09-15-2007 04:07 PM
Removing yellow reflector from Gen 2 Solara michaels_artic_ Solara 7 01-24-2005 02:26 PM
gas needle drops like a mofo RedruM Hardcore Tech and Competition 5 04-20-2003 01:47 PM
