I started a thread last year on my 1997 camry 5s-fe motor being seized up.
1997 Camry won't start but...
Well, the other day (Sunday, Jan 13 2008) I finally got done with the long block swap project after 3 loooonnnng months (about 200 hours total). I finished hooking up the battery and was eager to start her up. I put the key in the ignition and was happy to see the lights on the dash come up and the dingging noise from the door being opened. That was a good sign I thought to myself. As I held my breath, I turned the key.....and....nothing! Nothing happened. No clicks, no nothing. Well that just sucks @ss. First thing that came up to my mind was "the battery". I had previously charged it about 1 week earlier, but that was 1 week earlier. So I go ahead and leave it overnight charging. The next day I hooked the battery back up and proceeded to start her up again. Same thing. Nothing. So whats wrong???
I had double check the ground and there was one that was loose. I tightend that one up and the engine actually cranked and turned over when I went to start it up again. It sputtered and acted like it was choking and died like 5 seconds later. I waited 30 seconds and started her up again, this time added some throttle. She stayed running with my foot on the throttle, but as soon as I let go of the throttle she died. So later tonight after work, I go and start her up again. This time it just cranked and cranked and almost turned over but didn't. Did this like 4 times in a row. There seems to be a "clank" noise after I let go of the key coming from the passenger side.
*side note*
The two ground wires that is attached from the body on the driver side were the only two wires that I had no clue where they go. I don't remember where I took them off at. The factory service manual does not clearly tell me where they go. They are refer to as "ground strap connecter" on page EM-65 and with a blurry picture. The thing here is that on my camry, they are not straps; they have a ring washer type connecter at the end that looks like a bolt goes through it. So, I decided to attach one ground to one of the starter bolt and the other ground to the engine hook.
Ok, I am so stuck now. Possibilities that I came up includes:
a) throttle cable needs adjusting (it seems loose on the throttle body)
b) fuel filter needs replaced (i tried to get that damn thing out but it seems to be stuck/seized on the gas line; so I left it alone using the old one)
c) vacuum lines???
d) wrong ground cable location?
e) what else have I could of possibly done wrong?
P.S. I've never done any such work like this one before nor have I seen it done. I used the basic 300 piece craftsman tool box and a cherry picker for this job + the pdf gen 4 factory service manual. I already knew this project was going to take longer than a month and even longer because I work 48 hours a week (evenings) and have 2 kids and a wife going to school full time (mornings). I did however took some pictures and videos of the swap. I will post them soon when I get everything arranged out. Oh, and sorry for the long story post.
