RPMs changing - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2008, 11:21 AM   #1 (permalink)
Tedders's Avatar
View Tedders's Photo Gallery
3rd Generation RPMs changing
Hi, y'all.
So I have a '93 Gen 3 SE (6 cylinder manual 5 speed)where the RPMs do some odd things (Well, maybe; mabe not):
On startup in the cold, they go up to 2,000 and stay there for about 3 -5 minutes.
When I go to shut down the engine (I'm at a stop), they arise from about 750 to a little above 1,000, and then fall again to 750.
At idle with the engine warmed up (like sitting at a light), they're about 750. Then they drop a bit, the engine runs a tad rough, and then they arise again to 750.
After an acceleration and then coming to a stop (engine revved to about 3,000) the RPMs drop to a little above 1,000, pause, and then drop to 750.
Are these common patterns or is my engine possessed? If the latter, any ideas to exorcise it?
T'ank yew all.
Drive laughing!
Tedders
Tedders is offline   Reply With Quote
Old 01-15-2008, 11:47 AM   #2 (permalink)
toyota = cool
tacomonkey69's Avatar
View tacomonkey69's Photo Gallery
4th Generation
ive got a 97 v6 5spd and my car does the same thing on a cold start. but it drops back down to 1000 after driving for a while. i only noticed this after i installed a cold air intake on my car so maybe that is what causing my car to rev high on a cold start.
1997 Toyota Camry V6 5-Speed
1995 Lexus SC400...big plans for this one
tacomonkey69 is offline   Reply With Quote
Old 01-15-2008, 01:13 PM   #3 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
my car idles at 850rpm after it warms up. cold start it idles at 1100rpm. At extremely cold start it idles at 2000rpm.
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 01-15-2008, 03:23 PM   #4 (permalink)
View toyomoho's Photo Gallery
The engine control system has an idle up mode to increase RPM when cold. Idle is controlled by the IAC valve that can get dirty over time, try cleaning it. Be sure to use a cleaner that is safe for use with plastics.
Old 01-16-2008, 09:46 AM   #5 (permalink)
Tedders's Avatar
3rd Generation IAC valve?
Hey, thanks. Good suggestion.
But what is the IAC valve and where is it located? (Dare I say it?: It sounds like an easy fix!)
Drive laughing!
Tedders
Old 01-16-2008, 11:03 AM   #6 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
if you ask me, sounds like the iac as well
the iac is located right under the throttlebody
you can take the intake hose off and then just spray plenty of throttlebody cleaner on to the bottom of the TB and it will drain into the iac hole, hopefully cleaning it
HaHa
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
cold idle hunting (pulsing or surging) montreal 1st Generation (2003-2008) 5 12-30-2008 11:23 AM
94 corolla shakes at low RPM's gideon1331 Archived Corolla threads 49 10-18-2006 05:50 PM
