First time oil change = oil pump damage? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2008, 01:49 PM   #1 (permalink)
View ken_oy's Photo Gallery
3rd Generation First time oil change = oil pump damage?
I change the engine oil by myself one week ago. But after that the oil pump broken. I go to MIDAS, they ask for 1000 for repairing the Timing belt and the oil pump. And now everything seems ok again.
But I still afraid, I refill the engine oil, the the oil level is a little higher than the full level, I am just wondering is that the reason cause the oil pump broken? BTW, the car shop said the timing belt broken first and then it cause the oil pump broken.
And it is the first time I change the engine oil, if the oil level will cause serious problem, I will let the car shop do it next time.
Thanks for your help!
'95 Camry V4 2.2
ken_oy is offline   Reply With Quote
Old 01-15-2008, 03:27 PM   #2 (permalink)
Gameroom cash: $303055
A slight bit above the full mark will not hurt anything. If it really bothers you, drain out a bit and then recheck the oil level.
Mike
Old 01-15-2008, 04:27 PM   #3 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
I dont think it was anything you did that caused it. Dont feel bad. Save yourself the money and keep changing your own oil.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
oil change interval question nomad 2nd Generation (2005+) 15 06-29-2010 09:01 PM
1st oil change, 08 Corolla, Did I make the right choice? phs 9th Generation (2003-2008) 12 10-15-2007 04:44 AM
Synth. Oil Change Interval? Phi Hardcore Tech and Competition 46 09-18-2007 10:00 PM
X-RUNNER first time oil change motox500 2nd Generation (2005+) 3 01-25-2007 06:24 PM
funny oil change docktortal33 2nd Generation (2005+) 7 08-08-2006 03:17 PM
