I'm trying to remove a wheel from a 3rd gen. I've jacked up the car, removed all 5 lug nuts but the wheel won't budge. I thought the wheel was rusted to the hub so I sprayed penetrating oil but that hasn't helped either. I've also used a hammer to break it loose but that also didn't work. Does anyone have any other suggestions?
leave one lug nut in the wheel loosely to catch the wheel and kick it swiftly a few times with your heel and itll come loose
worse comes to worse, whack it a few times with a dead blow mallet
Got it off. I went to home depot and bought an 8lb sledgehammer. One mediocre swing and it was off. The cashier let me return it right after. Thanks for the help everyone.
lol reeboks. What he said, if this happens on your other wheels, put the lug nuts back on loose and not even finger tight, lower car to ground and drive forward and back up a few feet, repeat a few times and that ought to loosen the stubborn wheel.
Im guessing your wheels are aluminum, if they are or even if they are steel, i'd use anti sieze compound or at least a thin smear of wheel bearing grease on the inside of the wheel contact points to keep them from seizing on again.
thanks a lot to everybody
my front tire was stuck there too because of rust. didnt wanted to kick or tap it with the hummer. just went back and forward 2-3 feets, and that fixed it issue.
