Trans fluid dirty already? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-18-2008, 12:35 AM   #1 (permalink)
View ihartmacz's Photo Gallery
Before I bought the car the transmission fluid was changed at 191K, it reads as flushed. It doesn't say that a new filter was changed though. It also sais the cooler and the TC were flushed as well and refilled with "high tech" tranny fluid. No - it wasn't Jiffy Lube
Now, at 209K miles, the oil smells burnt and is filthy. I'm changing the filter, cleaning the magnets and refilling the bitch with some new Valvoline Dex/Merc this Sunday.
Isn't 18k a little too early for new fluid?
Also, my trans doesn't shift into OD until it's warmed up for a little while (till the needle is about 20% up the scale). Is this normal?
1993 5s-fe/auto
ihartmacz is offline   Reply With Quote
Old 01-18-2008, 01:02 AM   #2 (permalink)
touringcamry's Avatar
Gameroom cash: $510625
The car will sometimes not shift into OD so that the transmission and engine will heat up a bit faster.
If the transmission fluid was really not changed until 191k miles, and it was drained and refilled, it will be dirty after only 18k because drain and refill only exchanges about 1/3 to 2/5 of the total fluid.
2007 Camry 2.4L 5M
tranny dipstick? karosR6 2nd Generation (2005+) 18 04-11-2009 04:01 AM
Transmission Problems wareagle2000 2nd Generation (2005+) 21 07-23-2007 10:11 PM
Trans fluid 96GoldCam 3rd & 4th Generation (1992–1996 & 1997–2001) 3 05-20-2007 03:11 PM
