95 camry tach wire - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-06-2003, 10:44 AM   #1 (permalink)
sae
View sae's Photo Gallery
95 camry tach wire
I am in the process of installing a remote car starter in my 95 camry. I have been able to find all the wires I needed from bulldog security and 12volt.com websites. The only wire I am missing is the tach wire. Both the sites say you can find it on the coil, which makes sense, the problem is I cannot find it
If you know please let me know
sae is offline   Reply With Quote
Old 10-06-2003, 12:57 PM   #2 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Black wire.
On the 4 cyl. motor the black wire is at the check connector located on the rear side of the passenger strut tower. On the V6 the black wire is at the ignitor located on the drivers side strut tower.
Heres a scan I made of the wiring info from DEI:
http://trd.gotnet.net/wireinfo.jpg
"Skoolin' the unlearned!"
Old 10-06-2003, 02:01 PM   #3 (permalink)
Un-Official TN dude
View TypeZer0's Photo Gallery
do they have the wiring info on DEI's site somewhere? i've yet to find it and that seems to be much more complete and descriptive to me than bulldog's wiring guide
TypeZer0 is offline   Reply With Quote
Old 10-06-2003, 02:11 PM   #4 (permalink)
Grenaded piston
88 LE's Avatar
I don't think so.
I got the wiring info from a friend. The shop he works at carries stuff from DEI so they have the software.
Old 10-06-2003, 09:16 PM   #5 (permalink)
Crossdrilled and Slotted
View myconid's Photo Gallery
Im curious, can you take pics of what your install looks like? Specifically where you tap into the ignition switch under the dash. Im hesitant to start attacking mine..
myconid is offline   Reply With Quote
Old 10-06-2003, 09:39 PM   #6 (permalink)
Grenaded piston
88 LE's Avatar
The 12V, ignition, and starter wires are tapped off the 12 guage wires on the bottom of the steering column.
Old 10-07-2003, 08:30 AM   #7 (permalink)
sae
I wouldn't mind taking pictures for you, but I cannot do that because I don't have a digital camera. It's very straight forward though.
(the following instructions are for a 95 camry V6, not sure how it will change for other models)
There are four bolts that need to be removed at each corner of the "dash" under the steering column. Then remove the coin holder by pressing the sides in at the bottom. Removing the screws in there will reveal another screw, take that off, the "dash" should fall away, and you now have your ignition wires exposed. They should all be in a cluster with some kind of rubber wrapping keeping them together, I cut this off to give me access to the wires. I also removed the covering off the steering column so I could see which wires I lead from the ignition, but you might not have to.
The wiring diagram can be found here (bulldogsecurity.com):
http://bulldogsecurity.com/New%20Wir...oyotindex.htm.
I tested all the wires using a light tester. The tach wire is located behind the drivers side strut for the V6 and behind the passenger strut for the "four banger"
Then it's just a matter of taping into the wires. I just 18 guage "tap-in connectors" from radio shack, but I suggest using 16 gauge (or 14, whatever the wires are there). It was really too snug and tight with 18.
Old 10-07-2003, 04:16 PM   #8 (permalink)
Ride it like a Llama
miken517's Avatar
View miken517's Photo Gallery
i have that, trunk doesn't work though
I have the Bulldog security remote start. It was quite simple to install, even though it took me 4 hours in 50 degree weather. But it worked fine. It only cost me $50.
But i have a problem. I have everything working except the trunk button. It says that i can buy the extra wiring harness for the trunk (becuz it did not come with the original packaging). I was going to buy it, but the i went to a local shop. They said that i can't install the trunk harness becuz i have a "pull cord" trunk release. He said i would have to have an electronic trunk release for it to work. He also said that if i wanted it to work i would have to have a custom job done.
Is this true? I hope not, cuz i haven't had my trunk button functioning for about 1 1/2 years now. And i need it! Thanks for any help.
(Sorry this was a novel)
-'95 LE Dark Green.
-16" Motegi Gunmetal MR7's.
-OBX Muffler.
-Car PC in the Workz
miken517 is offline   Reply With Quote
Old 10-07-2003, 04:25 PM   #9 (permalink)
Grenaded piston
88 LE's Avatar
Re: i have that, trunk doesn't work though
You need a trunk release motor / silenoid and a relay.
Old 10-09-2003, 11:13 AM   #10 (permalink)
sae
I am not having any luck finding the black tach wire located at the drivers side strut tower by the ignitor.
I found a black/red wire which is alternating current from the tach, but I haven't found any black wire in that location.
Could someone please help me find my ignitor
Old 10-09-2003, 11:20 AM   #11 (permalink)
DJModifyd
alex's Avatar
View alex's Photo Gallery
yes its true
alex is offline   Reply With Quote
Old 10-09-2003, 01:20 PM   #12 (permalink)
miken517's Avatar
thanks alex for the post. DAMN no trunk release for me then. Hey Sae, today when i get home i will look up the tach wire for you, and i will post a response alright? Later
-'95 LE Dark Green.
-OBX Muffler.
Old 10-09-2003, 01:50 PM   #13 (permalink)
sae
That sounds wonderful, thanks.
In regards to your trunk release, I have heard it's quite easy to do. Just run some wires to your trunk and mount the release motor, aka soleniod (you can probably find one at a car wrecker)
Old 10-09-2003, 02:43 PM   #14 (permalink)
Grenaded piston
88 LE's Avatar
Dude are you not reading the replies?
I said you need a trunk release motor / silenoid and a relay.
Old 10-09-2003, 03:01 PM   #15 (permalink)
sae
I know, but I'm saying it's not difficult.
