Climate Control Help - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-19-2008, 12:39 AM   #1 (permalink)
View DanInDaNati's Photo Gallery
4th Generation Climate Control Help
Hi guys, I have a problem with my climate control unit. It's the manual type on a 99 Cam. All of the controls work except the blower motor doesn't come on until I turn the knob onto high. Does anyone know what the problem could be? Any help is appreciated! Thanks.
DanInDaNati is offline   Reply With Quote
Old 01-19-2008, 07:22 AM   #2 (permalink)
Gameroom cash: $401950
View Stillrunning's Photo Gallery
Fan speed resistor.
1995 Camry Wagon LE. 2.2 4cyl, 5S-FE, Auto, 185K
Stillrunning is offline   Reply With Quote
Old 01-19-2008, 03:45 PM   #3 (permalink)
Gameroom cash: $275055
Stillrunning is correct. You have a defective blower motor resistor. You can replace this yourself. Follow the wiring from the fan motor, located under the dash on the passenger side of the vehicle. You will see an electrical connector and 1 screw holding the resistor in. Remove the connector and the 1 screw and the resistor will come out. I believe this is a dealer only part and should run about $50 - $60.
Mike
HELP! Car won't Rev past 3000rpms supraskyguy 1st Generation (2003-2008) 26 09-19-2007 12:49 PM
Whiteline; Superpro and Dobinson Group Sale ...PART II raptorracing Supporting Vendor Sales 93 05-02-2007 06:02 AM
95 Corolla climate control lights not working rmaltz Archived Corolla threads 7 01-06-2007 07:09 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 11:53 PM
Headunit and Climate Control Colours terrynham Camry & Solara Lounge 8 05-20-2005 02:27 AM
