93 Camry WAGON - shocks/struts? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2008, 10:32 AM   #1 (permalink)
trimagna3's Avatar
View trimagna3's Photo Gallery
Unhappy 93 Camry WAGON - shocks/struts?
Seasick motion in 93 Camry Wagon?
I recently purchased a 93 Camry station wagon. It's generally in great shape but I find that, as the driver, I am starting to feel the onset of seasickness.
It has new Michelin tires, all around.
I checked the struts/shock absorbers by bouncing on the bumpers at the corners. They seem to be fine.
I think the light tail tends to float up on a bump. I'm leaning towards installing shock absorbers in the tail with stronger damping.
Does this analysis jive with your experience? What do you recommend?
trimagna3 is offline   Reply With Quote
Old 01-20-2008, 10:46 AM   #2 (permalink)
'93 LE Wagon, V6
View DFBonnett's Photo Gallery
How many miles on it? Can you tell if the struts and shocks are original? I've found that, for me at least, the bounce test isn't completely indicative of the need for replacement.
DFBonnett is offline   Reply With Quote
Old 01-20-2008, 11:41 AM   #3 (permalink)
Radio, this is Unit 91...
eurohazard's Avatar
View eurohazard's Photo Gallery
I fully agree ^. The "bounce test" works well with big American cars of yore. But even though my Camry's struts were toast, it didn't look too bad when I did the bounce test.
Do you have a picture of your car? One easy way to tell is by how low it sits when the struts are worn. Do you scrape on speed bumps that a normal car should clear?
1993 Camry LE 5SFE AT, 2006 Nissan Armada LE 4x4, 1971 Cadillac Coupe DeVille "pimp juice"
Toys: 2007 Coachmen 19FLB, 2007 Regal 1900 V6
I'm the biggest boss thatchu seen thus far! Baby, that's muh wi'zzard!
eurohazard is offline   Reply With Quote
Old 01-20-2008, 12:10 PM   #4 (permalink)
trimagna3's Avatar
Exclamation More info
171K. The front axle boots are ripped. My son says it needs front shocks.
Autozone shows 6 choices for front and five for rear.
http://www.autozone.com/N,14600660//...eResultSet.htm
http://www.autozone.com/N,14600661//...eResultSet.htm
Suggestions?
BILSTEIN cost more but claim to have a "touring" class ride. Are Bilstein actually better?
(HELP) 93 Camry Wagon Rear Wipers lugnut 3rd & 4th Generation (1992–1996 & 1997–2001) 2 01-22-2008 12:08 AM
Toyota's Globalization Takes Shape through the Camry 2007CamryXLE 5th & 6th Generation (2002-2006 & 2007-2011) 1 08-19-2006 06:52 PM
Toyota Camry Generations spdlva2nv4eva Camry & Solara Lounge 0 08-10-2006 11:45 PM
93 Camry with a few probs GaviN 3rd & 4th Generation (1992–1996 & 1997–2001) 1 03-06-2004 02:43 AM
93 camry wagon v6 glassj93 3rd & 4th Generation (1992–1996 & 1997–2001) 15 03-06-2004 12:46 AM
