Trans Lights on Dash come on when I wiggle the gearshift - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2008, 11:34 AM   #1 (permalink)
View Microman's Photo Gallery
USA Trans Lights on Dash come on when I wiggle the gearshift
I have never seen the "D" light on the dash of this 94 Camry. And I dont see the others unless I gently push the gearshift one direction or the other. I have read the threads about getting into the dash and replacing the D (Drive) light, but is there an adjustment or is my linkage loose, that causes this problem of wiggling or pushing up or down on the auto trans gearshift to see the lights come on.
Thanks...
Microman is offline   Reply With Quote
Old 01-20-2008, 11:44 AM   #2 (permalink)
Just a guess ....
The neutral safety switch, located on or near the transmission, in the engine compartment, is mechanically linked to the console gear shift selector. There are individual contacts within the NSS that determine which display lights are on. Maybe one of the contacts or connections going to the 'D' light, within the NSS, are not making effective contact, due to corrosion, oxidation, or maybe just loose.
Maybe check out the NSS for clean and tight electrical connections. Not sure if you can disassemble it ... Sometimes, depending on the assembly, you can spray on some electrical contact cleaner.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
91 Pickup Dash lights Lisa Sheree 89-95 Toyota Pickup/Hilux 10 03-13-2012 09:54 PM
Dash Lights Out Mr Urban 7th Generation (1993-1997) 11 08-29-2010 05:54 PM
Dash lights out mcalpine 1st Generation (1998-2003) 8 05-02-2008 09:04 PM
rear lights warning light on dash aussie_gen1 1st & 2nd Generation (1983–1986 & 1987-1991) 15 04-24-2007 08:28 PM
My dash lights went out! xavior66 Camry & Solara Lounge 5 08-03-2004 01:38 AM
