Tail Light - Bulb 904 Won't Fit! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2008, 01:54 PM   #1 (permalink)
View grinsalot's Photo Gallery
4th Generation Tail Light - Bulb 904 Won't Fit!
Hi,
I'm trying to change the tail lights (the ones next to the back-up lights on the trunk) on a 1998 Camry. According to the manaul, bulb 904 should do the trick. However, once positioned in the socket, the unit is at such a crazy angle that it won't go back in the hole. The bulb seems very large for this size hole. It just barely fits if I push it through by itself.
For background, the bulbs I removed were of type 194. I think the previous owner may have had the same problem. They work, but are somewhat dimmer. Additionally, the "lights out" dash indicator is illuminuted while using these bulbs. When I plugged in the 904's, the indicator is not lit.
Any suggestions would be appreciated.
grinsalot is offline   Reply With Quote
Old 01-20-2008, 02:17 PM   #2 (permalink)
Experience>Post Count
View MIC0417's Photo Gallery
Then put in new 194's
MIC0417 is offline   Reply With Quote
Old 01-20-2008, 06:11 PM   #3 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
IIRC, bulb 168 is a higher wattage bulb same dimensions as the 194.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-20-2008, 06:56 PM   #4 (permalink)
TN's furry friend
iTrader Score: 17 reviews
View WhiteRabbit's Photo Gallery
really? i thought they were the same.
WhiteRabbit is offline   Reply With Quote
Old 01-21-2008, 09:13 AM   #5 (permalink)
Darkside Cut Me!!!
Off the top of my head, 194 is 4 watt, 168 is 5 watt. I ran into this replacing some dash panel lamps and found my 2 new 168 bulbs were much brighter than the new 194 bulbs because I bought all the 194's off the shelf at the store.
2004 RX330 Sport
2003 Cam I4 XLE
Old 01-21-2008, 10:39 AM   #6 (permalink)
Thanks for your help, guys. I haven't tried the 168's yet, but won't I still have the same problem with the lights out indicator being illuminated? I'd still be shy on the recommended wattage. I checked the 904's and they're apparently 8.97 watts versus the 5 watts for the 168's. I assume that's why the indicator is lit. Am I wrong with this assumption?
Old 01-21-2008, 12:42 PM   #7 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
i put some 194 leds in some of my tail light spots and had no problems might try that and a load eq?
rebel8ball is offline   Reply With Quote
Tail Light Failure Sensor - NOT! driftinco 3rd & 4th Generation (1992–1996 & 1997–2001) 34 12-10-2011 04:13 PM
Bent Rear Tailgate Tsb! seinfeldfour 2nd Generation (2005+) 465 10-19-2010 01:38 PM
Tail Light Mod like Head Light Mod va beach taco 2nd Generation (2005+) 8 03-30-2007 12:26 PM
Real HID's not necessarily "better" fredster34 5th & 6th Generation (2002-2006 & 2007-2011) 26 12-11-2006 06:06 PM
Tail light warning dash light comes on everytime I turn on the headlights green94camry 3rd & 4th Generation (1992–1996 & 1997–2001) 5 10-01-2006 09:55 PM
