idiotic transmission fluid question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-20-2008, 10:00 PM   #1 (permalink)
View gpatkinson26's Photo Gallery
hey guys,
i recently acquired a 94 camry station wagon, and have found that the transmission fluid level is quite low ... do i add fluid to the tube where the dipstick goes or what? i don't see any other place.
thanks.
gpatkinson26 is offline   Reply With Quote
Old 01-20-2008, 10:06 PM   #2 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
yup.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 01-21-2008, 01:33 PM   #3 (permalink)
Gameroom cash: $303055
The dipstick tube is correct, but also check for leaks after topping off the fluid. Fluid is not consumed by the system, so it has to be leaking out somewhere. Also, be sure to use Dexron III fluid. It replaced the Dexron II that is mentioned in the 94 owner's manual.
Mike
Old 01-21-2008, 01:39 PM   #4 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Yes, add it through the dip stick tube, but be careful not to over fill it, auto tranny are sensitive to fluid level. Remember to have the engine running and warm with the tranny in park or neutral when you check the level. And yes use Dexron III.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 01-21-2008, 02:44 PM   #5 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
There is also a differential fluid reservoir that is separate. Check that too.
Kep
Old 01-21-2008, 02:51 PM   #6 (permalink)
touringcamry's Avatar
Gameroom cash: $550225
The difference between the low and high marks for the hot indicators is about 1 pt so be careful about how much you add.
2007 Camry 2.4L 5M
9th gen Transmission fluid exchange, observations and questions. cdherman 9th Generation (2003-2008) 36 08-24-2009 05:37 PM
Transmission Fluid? cowboycorolla Archived Corolla threads 5 09-13-2007 08:41 PM
Transmission fluid change question orbital Previa Forum 2 12-19-2006 01:18 PM
Transmission fluid change question orbital Previa Forum 0 10-04-2006 11:26 AM
