Master Power Window Switch - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2008, 09:00 AM   #1 (permalink)
youngflashycamr's Avatar
View youngflashycamr's Photo Gallery
3rd Generation Master Power Window Switch
Does it just pry out? what could cause it to fail? is a boneyard my best chance of getting one? Shanks, folks!
i like having had lulz.
also, shares his name with the first civic i got laid in.
AIM: imeffindash
Originally Posted by Venom_5 View Post
everyone IS entitled to an opinion .... yours is just wrong
youngflashycamr is offline   Reply With Quote
Old 01-21-2008, 10:03 AM   #2 (permalink)
View eilros's Photo Gallery
You'll need to remove the inner door panel to remove it. You can find them on eBay for a pretty reasonable price. You might want to use the For Sale board first. That's where I got mine.
eilros is offline   Reply With Quote
Old 01-21-2008, 11:36 AM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Before you condem the switch make sure that your wiring is good. Often, where the wires pass through the door, one or more wires will break. Check the DIY section for a post on accessing the switch itself. I understand some of the newwer Camrys can snap out but the older ones, mine included (a 1995 Gen 3), have to be unscrewed from the inside.Kep
Old 01-21-2008, 01:50 PM   #4 (permalink)
Gameroom cash: $303055
The link below (actually intended for speaker replacement) should help you with door disassembly. However, Kep is correct. Check that loom of wires first for broken wires.
Mike
http://rayrayonline.bravehost.com/frontspeaker1.htm
Just a little info I'd like to pass along.. Mr Marv Audio, Video, and Security - Tech 17 01-22-2008 07:49 PM
Power window switches on drivers door stopped working on 96 Camry. TommyN 3rd & 4th Generation (1992–1996 & 1997–2001) 5 01-12-2008 11:26 AM
PUZZLE - Rear window switch replacement. 96AvalonOwner 1st Generation (1995-1999) 2 12-07-2007 05:08 PM
How Make The Dummy Switches Work For Real - And Cheap Too... Hughes500Pilot 2nd Generation (2005+) 7 02-03-2006 10:42 PM
* * 91 MR2 power window switch * * imowt MR2 Forum 4 06-20-2005 09:36 PM
