Oil leak in 98 camry at Right side of engine... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2008, 02:30 PM   #1 (permalink)
View catlover7731's Photo Gallery
USA Oil leak in 98 camry at Right side of engine...
My hubby's camry has a bad leak..It has been leaking for a while, but we could never discover the leak.. The leak began after we changed the Timing belt at the dealer( we no longer live in the state to take it back there), now the leak is much more and last night hubby and neighbor went under hood and discovered the leakk is coming from the side of the right side of the motor.. My neighbor is a good mechanic, and he is going to go in there and see if the seal is missing or what. Any suggestions , ideas would be great . Thanks
catlover7731 is offline   Reply With Quote
Old 01-21-2008, 02:59 PM   #2 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Look under the timing cover to see if there is oil in there. If so, there is an oil pump seal in there, a Cam seal and a main engine seal. Any or all could be the culprit.
Also, loose nuts on the spark plug tubes. Tighten to 17 ft lbs.
Kep
Old 01-21-2008, 07:26 PM   #3 (permalink)
View digmycelica's Photo Gallery
Kep
And make sure you change the rubberband type seal behind the oil pump too.
digmycelica is offline   Reply With Quote
Old 01-21-2008, 08:55 PM   #4 (permalink)
View toyomoho's Photo Gallery
Might be an oil pump drive shaft seal. The oil would only drip when the engine was running making it tough to find with engine off.
4AGE swap 1992corolla 6th Generation (1988-1992) 26 09-11-2010 11:48 AM
20r Rebuild From Hell! nwdetectorist Pre-88 Toyota Pickup/Hilux 19 09-06-2007 09:38 AM
Part Deux; 20R REBUILD FROM HELL! nwdetectorist Pre-88 Toyota Pickup/Hilux 21 09-06-2007 09:35 AM
1992 Camry Oil Leak 4cyl kartracer03 3rd & 4th Generation (1992–1996 & 1997–2001) 18 02-04-2005 11:19 AM
