air blows but no heat comes out??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-21-2008, 05:16 PM   #1 (permalink)
View jonnyblackfoot's Photo Gallery
I have a 2001 toyota camry and the heat will not come on when i turn the knob to red. The air blows but it just produces freezing cold air. What should I do? Any advice would surely be appreciated. I am new to heating so specfic advice would be appreciated.
Thanks,
chris
jonnyblackfoot is offline   Reply With Quote
Old 01-21-2008, 05:45 PM   #2 (permalink)
EvoFire's Avatar
View EvoFire's Photo Gallery
Is the car warm? You don't get any heat when you first start the car, the heat comes from engine heat.
EvoFire is offline   Reply With Quote
Old 01-21-2008, 07:05 PM   #3 (permalink)
View Dr Thunder's Photo Gallery
If the car is warm (the needle is in the middle of the temp gauge) then make sure you have enough coolant in the radiator. If you do, and it still blows hot air, check the thermostat.
Dr Thunder is offline   Reply With Quote
Old 01-21-2008, 07:34 PM   #4 (permalink)
View digmycelica's Photo Gallery
Thanks,
chris
Sometimes the heater knob you turn with your hand will crack on the back side and you just think it's turning when actually the knob is stripped. pull the heat knob straight off and see if it is cracked. if so, pull the fan speed knob off and switch it to the heater knob post to see if it turns on the heat.
digmycelica is offline   Reply With Quote
Beginners Guide to Modification 89yotarollagts 6th Generation (1988-1992) 33 03-14-2009 04:27 PM
'00 GTS -Changed Coolant - What Happpened? No Heat & Runs HOT. Air Lock? 6-Speed Celica Forum 4 01-16-2006 07:43 PM
heat blows cold and hot, and overheats and cools dgreenhouse2003 Camry & Solara Lounge 6 12-16-2005 03:19 PM
Turbo the tercel? Flymasta K Tercel, Paseo, Starlet, and Sera Forum 19 01-30-2005 11:38 PM
Open air filter or panel air filter?? Della D. Turbo MR2 Forum 7 10-18-2004 06:04 PM
