Originally Posted by charley240sx
hmm... i dont have the slightest clue about this. the guy at autozone told me to check the purge solenoid, he wasnt 100% sure that he located it, but told me to remove and clean out. i dont trust many from autozone, but again, he seems to know more about this than i do.
kep, so you are telling me to remove all vacuum lines related to the evap and check etc?
Charley
i just went through my P0441 and P0446 on my 99 solara v6,
i replaced my charcoal canister, which contains all the valves such as purge valve, vaccum valves, etc.
the charcoal canister is under the car, right behind the gas tank, in between the two rear wheels. took me more than an hour to replace, only held by two 14mm bolts, and can slide out from the passenger side out without taking exhaust or control arm off.
i topped off my car at gas station everytime to round off to the next dollar and squeeze a few more miles, not knowing the excess gas that i pumped in after the pump clicked actually vapors to charcoal canister, soaking and shorten life of the charcoal canister.
there is also a TSB or recall in regard to the 97 98 camry v6 on the vapor/emission system, where the dealer replaces the charcoal canister free of charge if you have extended warranty i think.
