1994 Camry 4Cyl won't stay running for first 90 seconds
This car runs great. Only problem is when it sits all night, or I come home from work in the afternoon, and start it up, it will not stay idling without the gas being depressed. If I lift off the gas to put the foot on the brake it will stall. If I use two feet to keep it going (One on the gas, and one on the brake) , I can get it out of the drive way, and by the first stop it stays running, and is perfect.
Guy at one shop had me clean throttle body entrance, and remove that device below the throttle body with two screws. Had a little nub inside that would turn clockwise, and seemed to be tacky substance on with two screws.
Did that, but havent deteremined if that helped yet.
What would cause this 94 Toyota Camry with 4 Cyl to not stay running during first 90 seconds?
Thanks.
