Can anyone help me with my subwoofer? (vid inside) - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-22-2008, 05:35 PM   #1 (permalink)
Camryv6xle's Avatar
View Camryv6xle's Photo Gallery
3rd Generation Can anyone help me with my subwoofer? (vid inside)
Well my sub makes a heartbeat thumping sound whenever the car is running or just when its in the acc position. It thumps and while driving makes a whining noise while i accelerate, the only way to make it stop is to blast the music so it doesnt have a chance to thump , anyone know why this is happening? im starting to get very frustrated with all of it and thinking of selling it all and starting fresh but even then idk cause i have another amp and it does the same damn thing idk wtf is going on here
video:
http://s89.photobucket.com/albums/k2...roduction1.flv
http://i89.photobucket.com/albums/k205/gunit2049/0108091104-00-1.jpg
Camryv6xle is offline   Reply With Quote
Old 01-22-2008, 05:48 PM   #2 (permalink)
View TMetalMan's Photo Gallery
Interesting. My guess is there's some interference coming from something. Can you adjust the filter levels on your amp? If so, try messing with that a bit.
I have a 12" kicker in a home-built sealed box (sealed very tightly), and without any input the sub does move back and forth a little. If the box were ported it'd probably do half of what yours is doing. I wonder, could it be a Camry thing?
TMetalMan is offline   Reply With Quote
Old 01-22-2008, 05:55 PM   #3 (permalink)
View cerrucho20's Photo Gallery
3rd Generation
It look like there something wrong with ur amp
cerrucho20 is offline   Reply With Quote
Old 01-22-2008, 05:57 PM   #4 (permalink)
Camryv6xle's Avatar
my box is ported but i can fit it to but sealed, but its doing it with all the subs and the different amp i tried, idk wtf is going on but its seroiosly annoying and frustrating.
Old 01-22-2008, 06:13 PM   #5 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
Check that you have a clean ground, and maybe try another ground spot. You might have a ground loop problem. Also check your input cables to the amp. Make sure that they are run on the opposite side of your car from your power wires.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 01-22-2008, 06:15 PM   #6 (permalink)
Camryv6xle's Avatar
yea so far ive sanded down the neg area so no paint or nothing, and i got wires running separte sides of the cars, im just gonna rewire it tommorow and see if anything happens i think the problem is int he back of the head unit, or somewhere along the factory amp under the passenger seat
Old 01-22-2008, 06:22 PM   #7 (permalink)
'95 Camry 5S-FE
Double check that your input wires aren't run anywhere near any higher current wires, also check that your head unit is properly grounded too. The head unit is usually grounded from the casing to the mounting bracket to the frame, but if the screws or brackets are dirty you could have a bad ground which most likely would cause a ground loop.
Old 01-22-2008, 08:33 PM   #8 (permalink)
96 Camry LE
TopTeke's Avatar
View TopTeke's Photo Gallery
3rd Generation
Make sure you check your RCA cables as well at the amp inputs. Mine was doing the same thing this weekend and I adjusted the RCA's, problem went away for a short time. I think I will be replacing the RCA's and moving the cables even further away from the main power wire.
Best of luck!
TopTeke is offline   Reply With Quote
Old 01-22-2008, 08:38 PM   #9 (permalink)
kor-ro-ra?
midnightmach's Avatar
View midnightmach's Photo Gallery
Make sure your ground is good first. Also make sure your ground is the same gauge as the power wire. The whining noise would come from your power wire being to close to other electrical wires...
RIP Corolla & Camry.
midnightmach is offline   Reply With Quote
Old 01-22-2008, 09:29 PM   #10 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
anytime mines done that stuff my gain and bass boost were turned to high, and usually it was when i was trying to run off a stock stereo or at least into the high level inputs.
rebel8ball is offline   Reply With Quote
Old 01-22-2008, 09:45 PM   #11 (permalink)
Gameroom cash: $368576
iTrader Score: 15 reviews
View RichieRichJP's Photo Gallery
Yes, the gain or extra bass might be turned on. its possible you reversed the Negative and positive wires, which eventually will cause them to blow.
Other than that, no idea
RichieRichJP is offline   Reply With Quote
Old 01-23-2008, 08:44 AM   #12 (permalink)
JDM Inspired
Spitfire's Avatar
Gameroom cash: $122390
View Spitfire's Photo Gallery
ok are you running it off the stock system? if you do how did u hook it up... i might be able to help cause im running a system off my stock (500 wat amp and 2 12 " duals) < they arnt the greatest but they hit pretty good... im gettin ready to upgrade to 2 kicker comp vr's and a rocksford 1000 2 channel amp. im puttin the subs in a 4 ohm box lol its gonna sound good! 0.o
but anyways where exactly is ur ground at? i hooked up mine up to the locks for the back seats that fold down... just unscrewed it put the wire in a o ring and screwed it back up no cliping or whines or anything from bad ground
Spitfire is offline   Reply With Quote
Old 01-23-2008, 03:02 PM   #13 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
not sure if its mention, but try grounding your RCAs on the back of the head unit.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 01-24-2008, 08:49 PM   #14 (permalink)
View BaByBoiGsxR's Photo Gallery
3rd Generation
Yeah bro... mine use to do that too. Well, my very first set which was years ago. My advice is to do what everyone mentioned so far...
- check ALL wires, make sure they're all tight and properly connected correspondingly
- check for burns or cuts on the wires
- check how your amp is set/adjusted
........... OR .................
do what i did back then. Take your sub to a reputable audio place to test it. just be prepared for their response. cause when i took mine, what they told me was... "we checked it and you blew one of your coils." that's what causes that nasty rattling sound.
BaByBoiGsxR
BaByBoiGsxR is offline   Reply With Quote
Old 01-24-2008, 10:13 PM   #15 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
if you're talking about that buzzing-type of noise- can't really tell, since videos don't pick up bass that well - then it's distortion from the amp
the whining noise sounds to be a ground-loop feedback from your alternator...which is strange though, since that usually doesn't come through on subs or d-class amps...and usually occurs when running 2/4 channel amps powering components
as for the distortion of the amp...go bring it to a shop and get it checked out...and more importantly, stop playing your sub until you do. continued use of the amp will fry the coils in your sub
HaHa
Vid with longtub headers.. Ramenx 2nd Generation (2005+) 41 10-25-2007 06:03 PM
Bike Rack Inside Topper-'06 ratboyusn 2nd Generation (2005+) 19 06-03-2007 11:55 AM
Inside Windows Fogging Up When Car Is Not In Use bondbond55 5th & 6th Generation (2002-2006 & 2007-2011) 7 01-13-2007 09:14 AM
FS: Gen5 Camry Inside Door Handles, Dark Gray, OEM sn1cko Car Parts for Sale 0 11-19-2006 10:18 PM
Water inside the door Alex187 3rd & 4th Generation (1992–1996 & 1997–2001) 6 10-22-2006 01:42 PM
