93 Camry Oil Pan Leak.... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-07-2003, 06:15 PM   #1 (permalink)
View Neville07's Photo Gallery
Hey guys my pops just got a 93 camry and it is leaking oil like crazy. Im pretty sure its coming from the pan. We called the dealership for a gasket but we were told there isn't one and that they just use a sealer. Anyone ever use this? I've never dropped a pan before. Is it as simple as dropping the pan, cleaning the pan and the block, applying the sealer and then bolting it right back up? Any help would be appreciated. Thanks Guys.
Neville07 is offline   Reply With Quote
Old 10-07-2003, 06:30 PM   #2 (permalink)
93 Z24 and 78 Bronco
Nick's Avatar
View Nick's Photo Gallery
you got it! Mr. Gasket!
you might have to take off a section of the exhaust though
you might want to give the engine a good wash, wait a week, and have a look to see exactly where its coming from, could also be the head gasket or the valve cover
-Nick
Nick is offline   Reply With Quote
Old 10-07-2003, 07:33 PM   #3 (permalink)
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Re: 93 Camry Oil Pan Leak....
Felpro makes a gasket for the oilpan. You can get it at a autoparts store (Kragens, Autozone, etc...). I would still use rtv silicone with it though.
"Skoolin' the unlearned!"
Old 10-07-2003, 08:44 PM   #4 (permalink)
A SNAIL POWERS MY CAMRY!
View 5Sfte's Photo Gallery
It's a beeeach thying to pry the pan off without doing damage! The form in place gasket that Toyota uses is good stuff. I screwed my pan up when I took it off, luckily I had a brand new one that came with my turbo kit!
88 Camry 4CYL- Stolen, recovered, sold.
94 Camry 4CYL- Jacked up tranny, sold.
92 Camry 4CYL 4DR 5SPD- Ehh, it runs.
96 Camry 4CYL 2DR 5SPD- TURBO, 10PSI
http://www.myspace.com/camry5sgte
TN Map... Add yourself NOW!!!
5Sfte is offline   Reply With Quote
Old 10-07-2003, 08:58 PM   #5 (permalink)
Nick's Avatar
if you're gentle with a flat head screw driver it shouldn't be much of an issue
-Nick
Old 10-07-2003, 10:33 PM   #6 (permalink)
Hey guys thanks for all the replies. I'm on an N-body forum for my chevy malibu and its like pulling teeth to get replies sometimes. Anyway I started to clean up the engine but when i got underneath, i noticed that oil was everywhere. Intake manifold was covered! So its goin to the shop cuz its outta my league, the guy i know will do it for cheap. He did my malibu for about $300 when the dealer wanted like $1100. Anyway thanks for all the help guys i appreciate it.
Old 10-08-2003, 01:48 AM   #7 (permalink)
Nick's Avatar
if youre intake manifold is covered in it then its probsbly no tyout oil pan probably the head gasket or the valve seals
-Nick
