Valve spring compressor - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2008, 02:40 PM   #1 (permalink)
View super93camry's Photo Gallery
3rd Generation Valve spring compressor
Hey guys,
I have a 93 Carmy with 5sfe engine and 5 speed gear box
The engine was recently rebuilt at our local machine shop and everything was great.
Drove if for 3000 miles and then cluck, it started missing and tapping real loud.
I got it home and did a compression test and cylinder #2 had almost no compression!!!!
Took the head off and everything looked good visually at least, so I turned the head upside down on my work bench and filled each cylinder area with water to see which valve was leaking.
Sure enough cylinder number 2 exhaust valve started dripping water, so the question is......
Any ideas why the valve would suddenly stop sealing correctly?
visually it looks fine.
Also where and what kind of valve spring compressor do I need so I can remove the valve?
p.s. at the time of failure the engine was spinning around 2000 rpm's and I was down shifting gently!
Thanks
super93camry is offline   Reply With Quote
Old 01-23-2008, 03:01 PM   #2 (permalink)
Its out of warranty
Old 01-23-2008, 03:17 PM   #3 (permalink)
View toyomoho's Photo Gallery
The valve could be burnt or the stem bent, when the valve is removed you will know. Also check the camshaft lobe.
Build your own compressor see link:
DIY Valve spring compressor
Make sure you find the source of the tapping noise. The valve/seat could have been cut incorrectly, too little valve clearance, injector failure.
Old 01-23-2008, 08:34 PM   #4 (permalink)
ended up using a peice of cut copper pipe, worked great, theres not that much tension on the springs,
Thanks for the help
2009 Corolla S full test!!! 100$ GUY Toyota News 111 01-08-2008 12:47 PM
How to remove the valve cover. 2slo5sfe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 08-09-2007 12:26 PM
More bottom end out of your 3vz? try the ACIS.... v-cam 3rd & 4th Generation (1992–1996 & 1997–2001) 73 06-17-2007 07:48 PM
1999 2WD Tacoma Coil Spring Compressor bill70 Hardcore Tech and Competition 2 09-23-2005 03:02 PM
Rear shocks on a 96, drop down or need spring compressor? EMMETT03 3rd & 4th Generation (1992–1996 & 1997–2001) 1 11-15-2004 10:05 AM
