Abs Light Turns On - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-23-2008, 05:07 PM   #1 (permalink)
View Jorgeavi's Photo Gallery
Abs Light Turns On
Hello,
I have a 1998 Camry LE 4 Cyl, since the other day the ABS light turns and stays on when I start the car.
But if I turn the car off after warming up the ABS light works normal turns on for 3 seconds and then off.
I have researched and have not found this problem in any forum.
Does someone know why this is happening?.
Thanks And Regards,
Jorge
Jorgeavi is offline   Reply With Quote
Old 01-24-2008, 01:58 AM   #2 (permalink)
View Camry0099's Photo Gallery
Reset the battery, by disconnecting the negative terminal for 3 minutes then put back on.
Camry0099 is offline   Reply With Quote
Old 01-24-2008, 02:06 PM   #3 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
Get the code that is being thrown and check it out. Maybe there is something that causes a fault when it is cold but doesn't after it warms up. Up in NY I would expect that the brake fluid viscosity would be thicker and maybe the seals might be better after the system warms up. Don't know...
Kep
How many forum members does it takes to change a light bulb? hiace24 Off Topic 14 01-10-2008 09:19 PM
Problem with break, ABS, and engine light s7134 1st Generation (1998-2003) 1 12-19-2007 08:27 PM
ABS light on wasfishin Supra Forum 1 11-16-2007 12:06 AM
ABS light on, code 36, 71 bronzemaxell 3rd & 4th Generation (1992–1996 & 1997–2001) 0 08-20-2006 10:28 AM
ABS light stays on - 94 Corolla bertherr Archived Corolla threads 2 06-10-2005 07:10 AM
