tire/steering? dont know whats wrong - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2008, 06:21 AM   #1 (permalink)
The Camburger
iTrader Score: 6 reviews
View Admiral's Photo Gallery
Question tire/steering? dont know whats wrong
a while ago my car was driving crooked. had the alignment done. still driving crooked, so I went back and the shop told me my tires were bad (worn uneven). So I went home and put a new set of tires on. It drives perfect. yay! But now, after a couple hundred miles, it is starting very very very slowly to veer to one side again like it had before. But before I had just assumed I had a bad alignment. So I guess the question I have now is, what could be wrong with my camry that would be causing my tires to wear unevenly? please assist. thanks
It's the '95 V6
Admiral is offline   Reply With Quote
Old 01-24-2008, 12:48 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
Did you run into potholes or curbs recently? That can throw off an alignment.
Worn suspension joints like mounts/bushings, ball joints, rod ends, etc. could also be a culprit. At the alignment shop, the wheels get aligned, but they should also advise you about worn out or broken components that can affect alignment... usually they do.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-24-2008, 12:56 PM   #3 (permalink)
View bcsbadboys's Photo Gallery
I've had similar experience as you. Did you have a 4 wheel alignment done?
Other minor things: even tire pressure in all 4 tires, wheels balanced, etc...Maybe others can provide more ideas...
1997 Camry LE 2.2L, 5SFE
160,000
bcsbadboys is offline   Reply With Quote
Old 01-24-2008, 01:55 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
My first thought would be to check your suspension system over. Look for loose tie rod ends (ball joints), bent components and defective bushings (the rubber can deteriorate and/or shrink). If you find this and the alignment shop didn't mention it to you I would check around for alternative alignment shops the next time.
Kep
Old 01-24-2008, 02:12 PM   #5 (permalink)
Toyota | moving forward
islandboy57's Avatar
View islandboy57's Photo Gallery
Definitely get your suspension checked out. You don't want to ruin your new set of tires. I find it odd though that when you got your wheel alignment, nothing was mentioned to you if it is in fact something to do with your suspension.
'05 2AZ-FE @ 47K miles | '95 1MZ-FE @ 92K miles
moving forward
[Gen 5.5 - OEM fogs / FormulaONE tint / OEM rims / LEDs inside and out / Viper 1002 / EchoMaster]
islandboy57 is offline   Reply With Quote
BLEEDING BRAKES (What the hell am I doing wrong!!!) One_*_Star Pre-88 Toyota Pickup/Hilux 5 12-03-2007 02:08 PM
2007 Camry Speedometer WRONG? OneFlyGuy 5th & 6th Generation (2002-2006 & 2007-2011) 32 09-13-2007 09:27 PM
WTF is wrong with americian girls Aaagogo Off Topic 29 02-24-2005 11:58 PM
Anything look wrong with this picture? MrRavenX Archived Corolla threads 8 02-18-2005 04:04 PM
whats wrong with this mix? alex Off Topic 12 02-01-2005 12:13 AM
