power steering cooler - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2008, 10:49 AM   #1 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
i was wondering if anyone has pictures or a factory diagram of the oem power steering oil cooler and lines. the car is a 93 SE with the 3VZ and a 5spd. i have a fsm but in the manual it doesnt show a routing of the lines or a diagram. doesnt even mention the cooler.
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 01-24-2008, 11:37 AM   #2 (permalink)
View Bluecam6's Photo Gallery
I have a 93 v6 Wagon with AT. It has the power steering cooler on it. I don't know if the 5-speeds have the cooler on them they might. The ps cooling lines go from the back of the engine around the drivers side over the transmission to the radiator cooling fan( yes the fan is not electric but hydroloic) then from the fan it goes to the passengerside of the radiator
support and to the ps cooler. The cooler is located right in front torwards the lower part of the ac condensor. The the ps line goes back to the ps resivore on the passenger side next to the coolent overflow tank. The ps pump has 4 lines because it has a dual 2 vane pump in it. There are more ps lines then I descibed that go to the rack and pinion. You might go the toyota deal and
ask to the parts department about the ps lines and they might show you and print you a image showing all of the ps lines...........................................:e ek:
Bluecam6 is offline   Reply With Quote
Old 01-24-2008, 01:10 PM   #3 (permalink)
The ps cooler is located down low right in front of the ac condensor and radiator. Most toyota dealers parts departments will show these parts on there computer and print it for you.... The toyota service manual might not show this............................. 1989 camry v6 315,000 miles 1993 camry wagon 188,000 miles 1970 Chevelle SS 396 4-speed
'93 Camry Power Steering Problem joeantispam 3rd & 4th Generation (1992–1996 & 1997–2001) 20 10-23-2011 07:34 PM
Just a little info I'd like to pass along.. Mr Marv Audio, Video, and Security - Tech 17 01-22-2008 07:49 PM
Problem with power steering... movement 1st & 2nd Generation (1983–1986 & 1987-1991) 3 11-16-2007 08:45 AM
HELP: Ratcheting Noise in steering column when turning at low speeds... SIrMack 5th & 6th Generation (2002-2006 & 2007-2011) 29 11-14-2007 12:03 AM
