2001 Solara Swap problems - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2008, 01:41 PM   #1 (permalink)
View dvot's Photo Gallery
Thanks for reading my thread. This is my first post on this board and is a result of having some issues with a 2001 Solara. The car was a 5sfe automatic that spun its rod bearings. I swapped in a "JDM 3sfe" that was bought from eaby:
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
I modified the rear mount to facilitate the swap and swapped all components off the original USDM motor (cam pos sensor, camshaft sprocket, intake, coil packs, exhaust, etc, etc). The car cranked right up but misfires at idle (rough running).
Has a slight stumble on acceleration as well which seems to be due to the misfire. It seems to be running very rich judging by the rich smelling blue smoke coming from the exhaust as well as the fact the plugs will be coated black after any amount of running. I have swapped plugs/wires/coil packs, checked every ground strap and sensor. There is no check engine lights. I seafoamed the intake to clear any carbon build-up.
I was very careful when I swapped the USDM cam sprocket to get the timing set dead nuts on. I checked that the cam and crank TDC marks were aligned perfectly and rotated several time. Checked compression and it is the same across the board. I am a professional mechanic and this is a customer's car and I have run out of option. I was hoping maybe some of you guys on this forum were familiar with the swap from the 2.2 to the 2.0 and if there were any common hangups that I cannot seem to sniff out. Thanks for taking the time to read this post and hopefully someone can help.
dvot is offline   Reply With Quote
Old 01-24-2008, 02:01 PM   #2 (permalink)
Lone star
blackhawk's Avatar
View blackhawk's Photo Gallery
man sorry to here that .. umm i would post it in the solara section of the forum and solaraguy to increase your chance at getting answer you require
I HAVE NO IDEA HOW THIS WORKS
blackhawk is offline   Reply With Quote
Old 01-24-2008, 02:01 PM   #3 (permalink)
View J_Phu's Photo Gallery
have you tried retarding or advancing the timming
J_Phu is offline   Reply With Quote
Old 01-24-2008, 02:22 PM   #4 (permalink)
There is no distributor to advance or retard the timing. Thanks for the replies.
2001 Solara Keyless Remote zachary1988 Introduce Yourself Here 1 01-23-2008 08:59 PM
WTB: TRD bodykit for 2001 solara pundaegg Car parts for trade or wanted parts 1 12-28-2007 12:30 AM
2007 Toyota Solara Pricing lexusis350 Toyota News 50 06-06-2006 05:49 AM
2001 Solara Fuse Box bobbyuofl Solara 3 04-19-2005 11:04 PM
2001 convertible solara MontrealJoseph Solara 2 08-02-2004 02:35 PM
