97 camry fuel door wont open tried many diff things - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-24-2008, 04:47 PM   #1 (permalink)
View star_classic's Photo Gallery
my fuel door just decided it doesn't want to open today i've tried propping up the release latch and trying to pop it open with a credit card/key, doesn't seem to work, i don't have a release latch in the trunk, and i can hear the mechanism moving in the fuel door but nothing happens i have no idea what to do i'm tempted to pry it open till it breaks and then just replace but if don't have to i won't plz help
star_classic is offline   Reply With Quote
Old 01-24-2008, 05:00 PM   #2 (permalink)
Super Moderator
eyeball96's Avatar
Gameroom cash: $906927
iTrader Score: 59 reviews
Try puting the credit card and pushing it in mid way in the crack, as far as u can then pry..u have to release the latch with it...maybe the spring that shoots it open has broken...I fixed my daugters 99 with a bent document clip, (its like a large paper clip)..I'll try to find the post!
96 Camry Coupe LE V6
98 Honda CRV
08 GMC Crew
11 Kia Sportage EX AWD
Old 01-24-2008, 05:07 PM   #3 (permalink)
Import Tuning
camry man68's Avatar
View camry man68's Photo Gallery
Thats a big problem among camrys and one toyota can never seem to fix, i got that too and i use a card if that doesnt work then just keep trying with different things. Use 2 cards maybe.
camry man68 is offline   Reply With Quote
Old 01-24-2008, 06:52 PM   #4 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
On my 95 Camry sedan I can peel the trunk liner back from the side and see the latch mechanism. I can also reach in and press the cable release and it opens the door. It looks like you could help it by spraying it with WD40. Check also to verify that the cable body is unbroken. If the plastic exterior breaks then it doesn't transfer the pressure to the end correctly.
Kep
Old 01-24-2008, 07:37 PM   #5 (permalink)
View lenjack's Photo Gallery
If the spring is broken, your dealer will have them for about $5.
lenjack is offline   Reply With Quote
Old 01-24-2008, 07:43 PM   #6 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
I had this happen many years ago with a different Toyota.
Find an assistant. Have the assistant pull the fuel door release lever, while you jiggle with the fuel door manually.
If you're lucky, you'll get it open.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is online now   Reply With Quote
Old 01-24-2008, 07:48 PM   #7 (permalink)
View trogdor71's Photo Gallery
The little spring (looks like a binder clip as someone I think said) broke off my fuel filler door awhile back and it stays locked since the release doesn't pop it open under spring pressure anymore. I have a little bottle of hand lotion my wife keeps in the car that I use to hold the release lever up with and then I can pull open the door. I really want to fix this.. I should do a search on that fix mentioned..
trogdor71 is offline   Reply With Quote
Old 01-24-2008, 07:51 PM   #8 (permalink)
View Cannonbolt's Photo Gallery
Had the same issue with my 99, this is what I did. First, it took 2 people to open the gas door. One to pull the hold open then switch in the floor and a second to open the gas door. Normally, there's a little metal clip/spring that pops the door open when you pull the switch (I know not which it was because I never noticed it until it was gone...) But I just took a small piece of relatively thin, bendable metal, bent it into a V shape, test fit, JB Welded it into place, and voila - it works again! Good luck.
Cannonbolt is offline   Reply With Quote
Old 01-24-2008, 07:58 PM   #9 (permalink)
View Undertow's Photo Gallery
I have the same problem on mine, the lever won't open the fuel door but I can just pry it open with my keys or a credit card.
'97 Grey Camry 5SFE 69,000 miles
Eibach Springs and Tokico Struts installed :]
Undertow is offline   Reply With Quote
Old 01-25-2008, 05:26 PM   #10 (permalink)
As said earlier, a $5 spring from a Toyota dealer, self installed in one minute for the fix.
Old 01-25-2008, 10:33 PM   #11 (permalink)
As said after this, save yourself $5 and a trip to the dealership. A metal to metal bonding agent and any thin, pliable metal scrap you can find will work.
Old 01-26-2008, 01:23 PM   #12 (permalink)
Location: San Diego CA, Glen Cove NY,Fairford UK,Cedar Rapids, IA
Gameroom cash: $279892
View csaxon's Photo Gallery
It worked fine until I fixed it!
csaxon is offline   Reply With Quote
Old 01-26-2008, 01:32 PM   #13 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
And if none of those suggestions work, remove the fuel door and tank completely, chop a hole in the floor in front of the driver's seat, and flintstone your ass everywhere. It's great exercise and saves you tons in gas!
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 01-26-2008, 02:10 PM   #14 (permalink)
NBBADTOYS
View keisuke's Photo Gallery
the lock pin light be seized, it was on mine its a 60 dollar part and its 60 to install, it goes from the lever to the tank lid
1997 Toyota Camry XLE V6- 308500 and counting
keisuke is offline   Reply With Quote
Old 01-26-2008, 04:00 PM   #15 (permalink)
DIY : I believe
Maim Menu's Avatar
View Maim Menu's Photo Gallery
That's what I've been doing for the last couple years and it works great. Even got a refund from the government because of my unreasonably low emissions car. I've found out that my legs are faster than a 5sfe too.
In all seriousness I've got the same problem with the fuel door. I just hold the lever it up with my tire pressure gauge and press on the left side of the door to get it to open. I haven't taken the time to "investigate" but if it's a one minute fix I'll probably have a peek at it before this summer cause it's pretty annoying.
Restoring '65 Chevy Impala Super Sport w/ 327-300 small block, Edelbrock carb/intake and T-5 tranny that will probably blow up.
Black '98 Camry LE 4Cyl Auto, 188 000Kms and counting
Black '98 Camry CE 4Cyl Auto, 295 000Kms and counting - SOLD
Maim Menu is offline   Reply With Quote
1998 Camry 5SFE 4-cyl idle long-term fuel trim ionosphere80 3rd & 4th Generation (1992–1996 & 1997–2001) 18 09-12-2007 11:22 PM
Overall Comparison: Toyota Camry XLE V6 v.s. Pontiac Grand P CamryLeb Camry & Solara Lounge 25 08-13-2007 10:55 PM
OBD-II Trouble Codes: Full List! thespud Corolla Lounge 0 07-30-2006 10:53 PM
95 camry fuel pump connection questions dwmoss 3rd & 4th Generation (1992–1996 & 1997–2001) 2 09-24-2004 12:45 PM
