3sfe vs 5fse - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-25-2008, 06:40 PM   #1 (permalink)
View Quib's Photo Gallery
3sfe vs 5fse
I have to change the engine in my 99 Camry LE and have been researching my options (and learning a little along the way). Ebay sellers have been advertising 3sfe 2.0L JDM engines as replacements for the 5sfe 2.2L engines, citing that the codes are different between Japan and the US and that they are the same engines. Are they the same engines (block and head) or are they actually different engines? I've seen several posts where 3sfe's were successfully swapped with little to no difficulties and other posts have reported major difficulties. If I go with a 3sfe engine, does it have to be from the same generation (97-01)? Can the rear bracket from the old 5sfe engine be swapped to the 3sfe engine (to keep from drilling new holes)?
One more question. I'm not a mechanic, but I have worked on my vehicles before. How hard is it to do the engine swap? Is it fairly straight forward as to unbolt and bolt back on or are there subtle problems that will come up? Are their any diagnostic testings that need to be done to fine tune the engine?
I know this is a long post, but I would appreciate any help I can get. Thanks.
Quib is offline   Reply With Quote
Old 01-25-2008, 06:51 PM   #2 (permalink)
'95 Camry 5S-FE
Gameroom cash: $267767
View 95PimpingCamry's Photo Gallery
They are almost they same engine, except the 5s is a 2.2L and the 3s is a 2.0L, so the 3s has less power.
All of the lag, none of the boost.
VTEC It's like waiting for really bad sex.
95PimpingCamry is offline   Reply With Quote
Old 01-25-2008, 11:29 PM   #3 (permalink)
OOOOOOOKKKKKKKK!!!
I finally got a little time to research this topic a little in the archives and just finished reading the infamous thread from 2003.
I would prefer to go back with the original type of engine that is in the car (5sfe) but finances made the 3sfe engine attractive, based on the claims of the sellers and results posted by other members of the forum.
Prices quoted on 5sfe engines back in 2003 seem awfully low compared to today's prices. Are they that expensive now? One local shop quoted me a price of $1650 on a JDM 5sfe. ???? Ebay prices seem awfully high also.
Anybody have suggestions?
Old 01-25-2008, 11:34 PM   #4 (permalink)
Import Tuning
camry man68's Avatar
View camry man68's Photo Gallery
To answer your question about whether or not a swap is complicated, well it is. There are so many things that you have to take into consideration and do that im going to bother to list them.
As to your choices of engines go with the 5sfe unless you can afford the 1mzfe v6 camry engine.
camry man68 is offline   Reply With Quote
Old 01-26-2008, 01:31 AM   #5 (permalink)
Tom 2000's Avatar
Gameroom cash: $200700
View Tom 2000's Photo Gallery
Try to stick with the 5S-FE. The late JDM 3S-FE has about the same horsepower, (140 HP JIS), but less torque. When you put U.S. emissions equipment on it from your engine, it'll choke it down more.
Tom
2004 Prius Touring Edition
2003 Corolla Luxel
2000 Camry LE - Lunar Mist Metallic
Tom 2000 is online now   Reply With Quote
Old 01-26-2008, 07:52 PM   #6 (permalink)
Thanks, guys, I'm about convinced that I need the 5sfe engine and somebody else is putting it in for me.
Thanks for the help.
89 3SGE / 3SFE interghangable parts 89GTS Celica Forum 12 07-10-2006 09:24 AM
Gen2 3sfe (USDM) vs. Gen3 3sfe (JDM) - What's the Difference? airswoosh1 1st & 2nd Generation (1983–1986 & 1987-1991) 15 12-24-2005 12:10 PM
Thinking of swapping 2vzfe V6 for 3sfe I4 es250nut Camry & Solara Lounge 17 07-29-2005 09:01 AM
Old 3sfe ECU incompatible with new 3sfe? Talisman Hardcore Tech and Competition 8 05-15-2005 03:27 AM
3SGE and 3SFE, lets get our heads together almc2242 Hardcore Tech and Competition 9 01-27-2005 03:58 PM
