brake line diagram - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2008, 04:50 AM   #1 (permalink)
SE V6 5spd aficionado
mazdaverx7's Avatar
Gameroom cash: $142520
View mazdaverx7's Photo Gallery
brake line diagram
i'm looking for a diagram of the routing of the brake lines for a 93 Camry SE. the vehicle is equipped with abs and has the rear LSPV(load sensing proportioning valve). if someone has pics that would be fine too!
92 Camry SE 3VZ-FE 5spd 131K 6m1
85 Porsche 944 119K 5spd
88 RX-7 10AE 96K 5spd
85 RX-7 GS 5spd
05 RX-8 38K 6spd, 63 Ford Falcon 99K I6 3spd
mazdaverx7 is offline   Reply With Quote
Old 01-26-2008, 09:12 PM   #2 (permalink)
mazdaverx7's Avatar
more specifically from the master cylinder to the rear of the vehicel and to the lspv
85 RX-7 GS 5spd
Old 01-28-2008, 09:36 AM   #3 (permalink)
mazdaverx7's Avatar
anyone???
85 RX-7 GS 5spd
Old 01-28-2008, 11:56 AM   #4 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
when you say rear proportioning valve, do you mean that it's located in the rear of the car???
because in the 94, it's in the front of the car....but yes, it's for the rear brakes (of course).
sorry it took so long, but here's a diagram:
HaHa
Old 01-29-2008, 08:48 AM   #5 (permalink)
mazdaverx7's Avatar
thanks for the pic!! yes, on my 93 SE V6 the vehicle is equipped with abs and uses a load sensing proportioning valve. the unit is mounted to the rear under body and uses a lever and a spring that are attatched to the left rear outward lateral control rod. as the suspension flexes under hard braking it will rise as teh nose dips, causing something to happen in lspv. i can post a pic tonight of what i'm lookign at. i'm replacing the brake lines.
85 RX-7 GS 5spd
Old 01-29-2008, 02:06 PM   #6 (permalink)
mazdaverx7's Avatar
i took some pics of the lspv today if anyone would like to see it
85 RX-7 GS 5spd
Old 01-29-2008, 04:51 PM   #7 (permalink)
mazdaverx7's Avatar
here you go:
85 RX-7 GS 5spd
Old 01-31-2008, 06:21 AM   #8 (permalink)
mazdaverx7's Avatar
pretty odd little creature isnt it?
85 RX-7 GS 5spd
Old 01-31-2008, 12:55 PM   #9 (permalink)
TN Pussy Man
hmm...that is actually really neat....and probably specific to the SE braking system as well...
I could see that being a pretty neat function since it seems to "feel" the rise of the rear of the car, and presumably, then put more braking power to the rear through transfer of the brake fluid
HaHa
Old 02-01-2008, 08:34 AM   #10 (permalink)
mazdaverx7's Avatar
that seems right. the whole assembly was rotten and i could not afford a replacement, so unfortunatly i had to bypass it.
85 RX-7 GS 5spd
Old 02-01-2008, 12:28 PM   #11 (permalink)
TN Pussy Man
that's too bad...
but I would have liked to see some comparisons between hte performance of the cars without that little feature and the ones without...I can see flatter braking and cornering with the system, but also possible worse straight line stopping...
ah, speculations, speculations...
HaHa
Old 02-02-2008, 07:56 PM   #12 (permalink)
mazdaverx7's Avatar
i agree. i have an article floating around with the comparisons....i'll check that and post back
85 RX-7 GS 5spd
Old 02-02-2008, 08:16 PM   #13 (permalink)
mazdaverx7's Avatar
ok, the article states that the 92 camry XLE stops from 70-0 in 178ft and the 93 Camry SE V6 with a 5spd stops form 70-0 in 180ft. doesnt state whether eithe has abs or not.
85 RX-7 GS 5spd
Old 02-03-2008, 01:57 AM   #14 (permalink)
TN Pussy Man
ah...that makes sense...
and as for abs...at least in canada, all the XLE's had ABS and to the best of my knowledge, same with the SE's here
only for the LE- be it 4banger of v6, ABS was optional
HaHa
Old 02-03-2008, 04:42 AM   #15 (permalink)
mazdaverx7's Avatar
it would be nice to have abs on my 93 Camry SE V6 5spd. no such luch though..
85 RX-7 GS 5spd
90 4runner brake line question-please help! misterfixit 4Runner Lounge 0 12-27-2007 09:08 PM
Rear Drum Brakes Syndacate Tercel, Paseo, Starlet, and Sera Forum 13 08-20-2007 02:56 PM
AE92 Sedan Brake Line Options? truelementx Archived Corolla threads 3 04-03-2007 02:02 PM
metal brake line broken 94dsm 3rd & 4th Generation (1992–1996 & 1997–2001) 0 08-15-2006 06:47 AM
