Hello guys, let me first introduce myself. I'm a new member here at Toyota Nation and my family have own a lot of Toyota vehicles. I have some general knowledges about cars and once in a while I do this and that to fix the car. I mostly do the maintenance and repairs myself rather than bringing to the shop.
With that being said, please forgive me for making any mistakes. I took out the engine from a 1992 Toyota Camry 3.0 V6 to change the transmission. Everything went perfectly fine and was able to drop the engine and transmission back in fine. I got everything connect back together, then I started to turn on the car, and the car would not even crank as if the starter is not running. I know the starter is fine and I even put another good starter in to test but it won't crank and starter won't even rotates. So after some frustrations I found there is a connector that is hanging unplug. I don't know if this is the igniter connector or what it is and where it suppose to plug to.
Here are some pictures:
The connector/wire is under the plenum and throttle body.
Thanks in advance for your helps.
