milky substance on oil cap - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-26-2008, 07:24 PM   #1 (permalink)
View tmarsh's Photo Gallery
Unhappy milky substance on oil cap
I opened my oil cap and found a thick milky white substance coating the top. I am assuming it is coolant. My question is why. My car doesn't sound like it has blown a head gasket (been there before). Haven't had any noticeable loss in power (in fact I thought to myself the other day it seemed to have a little pep in its step). I have replaced the pcv valve in the last month and a half, their is an oil leak, seemingly from the valve cover gasket near the distributor, (I had the oring leak fixed over a year ago) and I have driven it perhaps twice when oil was low. I know that isn't good but would that do any damage that would be slow to show?
Any help would be appreciated.
Also, I have a power steering leak - an inner boot on the passenger side i leaking the fluid. Any idea on the cost to fix that? Thanks
Aaron
tmarsh is offline   Reply With Quote
Old 01-26-2008, 08:45 PM   #2 (permalink)
Which engine .. year ....?
Have coolant system pressure tested...
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
Old 01-26-2008, 08:46 PM   #3 (permalink)
View ihartmacz's Photo Gallery
That's sludge.
If coolant was leaking into the oil, you'd know.
ihartmacz is offline   Reply With Quote
Old 01-26-2008, 10:09 PM   #4 (permalink)
97 Camry '8ball EDITION'
rebel8ball's Avatar
View rebel8ball's Photo Gallery
if tis a tiny amount i have seen it happen when the temps swing wildy, condensation forms and you get milk.
rebel8ball is offline   Reply With Quote
Old 01-26-2008, 11:57 PM   #5 (permalink)
xtremeskier97's Avatar
Gameroom cash: $199080
View xtremeskier97's Photo Gallery
Sludge isnt as milky as coolant in the oil is. Sludge is a little thicker than milky in my opinion. A picture would help determine which it is. Check your coolant level. It if is low...then have it pressure tested.
1993 Camry LE I4 Bone Stock - 380,000 miles (as of Aug '11)
1993 Camry XLE V6 Bone Stock - 260,xxx miles (as of July '11) Blown Head Gasket
2003 Chevy Trailblazer EXT I6 - 107,000 miles (as of Aug '11)
xtremeskier97 is offline   Reply With Quote
Old 01-27-2008, 01:40 PM   #6 (permalink)
Gameroom cash: $303055
It could also be as simple as condensation formed from a lot of short trip driving. Condensation is a byproduct of combustion, especially on a cold engine. When you first start your engine this condensation is formed as the cold engine begins to warm up. If you drive the car long enough, that condesation is evaporated by the heat of the engine. If you make frequent short trips this condensation never leaves the engine. It will pool under the oil cap. It's usually tan to light brown in color though, not white. Do you frequently do short trip driving?
Mike
Old 01-27-2008, 01:54 PM   #7 (permalink)
Avy drivin' fool
swiftjustice's Avatar
View swiftjustice's Photo Gallery
I think Mike has it right. That type of condensation is typical of the following:
1. Predominantly short trip driving. The engine is not getting hot enough for a long enough period of time to burn off all the condensation, especially during the wintertime.
2. Blocked engine breathing system (i.e. PCV valve or atmosphere vents on earlier engines)
3. Coolant system compromise, usually the head gasket.
I'd start with number one and move down the list in searching for the problem.
1995 Avalon XLS
2005 Sienna LE
1967 Mini, Cooper S spec.
swiftjustice is offline   Reply With Quote
Old 01-27-2008, 02:50 PM   #8 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
milky crap in the oil cap is from moisture not making its way to the PCV valve. now if your dipstick showed milky crap, then yes you have larger problems...head gasket. sludge looks like somebody baked something and let it go for 1hr more, burnt to a crisp, if you touch it it will turn to a crunchy/goey substance. this is from heat, and lack of oil changes.
but if your oil cap has a recess in it (i expect it does), then the moisture will be traped there.
want a good laugh, find a dodge ram with a 4.7 V8, the oil caps get milky as all get out! nothing wrong with the engine, just stupid design.
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 01-28-2008, 10:25 AM   #9 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
That tiny amount is condensation.... looks like dark toffee is some oil, moisture and fuel.
Check the oil on the dipstick to reassure yourself.
If you take a long trip (like 30 minutes) on the highway, the engine can heat up the oil and then evaporate the moisture and fuel inside.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-28-2008, 12:06 PM   #10 (permalink)
View mvftw's Photo Gallery
Very simple to check...just change your oil & filter. If it comes out like chocolate milk...your done...if it's black, then your Ok, it's just condensation as mentioned. Also change your brand of oil that can help...
mvftw is offline   Reply With Quote
Old 01-28-2008, 12:40 PM   #11 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
Agree with mike, sounds like condesation. Had a similar issue.
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 01-28-2008, 01:50 PM   #12 (permalink)
Quasi-Evil Monkey
renmike's Avatar
iTrader Score: 14 reviews
View renmike's Photo Gallery
3rd Generation
Yeah, condensation sounds like the most likely cause, especially if when checking the oil on the dipstick it looks fine.
Current Ride(s): 08 Pontiac G8, 02 Mitsubishi Lancer, 94 GMC Sierra
Former Ride(s): 93 Camry SE V6 5-Speed , 95 Camry DX 4-cyl
renmike is offline   Reply With Quote
Old 01-28-2008, 08:26 PM   #13 (permalink)
So I took the car to a mechanic, He said the engine is in bad shape. Something about the piston rings having alot of blowback. He said if you pull out the dipstick while the engine was running oil spewed out. Something about too much pressure. Said something about some misfiring as well, but I don'there it, or feel it, whether at a slow speed or on hwy. I started tuning him out when it sounded like life was about to suck. He reminded me, and I forgot to mention that I had a leak in the radiator and had it replaced. I don't think my engine overheated, but he kept asking me if that happened.
He said My choices were to get a new engine, or rebuild. Either way...$$$
Please offer up some hope. If a rebuild or new engine is necessary can you give some advice.
BTW - it is a 94 manual 4cyl.
Thanks.
Old 01-28-2008, 08:58 PM   #14 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
This sounds like the time to get a second opinion. There are tests that can be done to determine if there are exhaust fumes getting into the coolant or if there is blow by. Oil in the coolant definately is a concern and needs to be fixed if it is indeed there.
The suggestions above are all pertainent. Is the oil on your dip stick also milky? Have you checked to see if your PCV valve is clean (it should rattle when you shake it)?
Need more information on the blown radiator. If an engine is run without being pressurized, I understand that it can damage the engine because the coolant doesn't circulate as designed, even if the temperature gauge doesn't show an overheating situation. Doesn't automatically mean that there was damage but there may need to be more checks.
Kep
Old 01-28-2008, 10:05 PM   #15 (permalink)
Gangsta SC400 & 5.7Tundra
iTrader Score: 35 reviews
View -SCWEET1-'s Photo Gallery
-SCWEET1- is offline   Reply With Quote
DIY: Oil Change w/ pics 5.7L mhadden 2nd Generation (2007+) 14 02-05-2012 03:04 PM
2007 Camry Oil Change FYI! Wizrd23 5th & 6th Generation (2002-2006 & 2007-2011) 139 11-05-2011 07:36 PM
Mobil1 5w-30 Synthetic and my 2002 Corolla??? gadawg Archived Corolla threads 6 01-26-2004 04:39 AM
Custom oil fill cap Meisner General Discussion 3 04-25-2002 09:37 AM
