Rattling noise at Timing Belt - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2008, 01:03 PM   #1 (permalink)
View kruang's Photo Gallery
USA Rattling noise at Timing Belt
I started the car this morning. After a few minutes, a rattle noise comes out from the Timing Belt area non-stop. When I look there, I saw the belt has some oil on it and see a bit of white smoke comes out from that area. Also, I saw some oil on the floor. I searched the forum and it seems to point to T-belt tensioner, but I couldn't find anyone that also saw smoke. Anyone has idea of what else could be the problem? Thanks.
kruang is offline   Reply With Quote
Old 01-27-2008, 02:52 PM   #2 (permalink)
Dealer Tech..not Toyota
Axel Kain's Avatar
View Axel Kain's Photo Gallery
time for a timing belt, and water pump at least, plus sealing what is leaking, possibly cam's/crank seals...have to get in there to find out!
Quote-Terrastrife: Axel the confusion specialist!
-1992 Camry V6 XLE- *3VZ-FE* (with a dead auto trans.) <SOLD!
Newest addition- 1987 300zx Turbo! what a blast!
Axel Kain is offline   Reply With Quote
Old 01-27-2008, 08:47 PM   #3 (permalink)
TN Pussy Man
Eye8Pussies's Avatar
Gameroom cash: $395960
iTrader Score: 13 reviews
time for a timing belt change and to get that seal fixed...if it's enough to smoke and drip, then it's pretty bad. and hte noise will most likely be the pulley
I would say that one of the camshaft seals is leaking since it'll then drip along the block and create smoke.
I doubt that it's caused by the tenioner since if the tensioner went bad , the belt will be loose and the timing would also be off for sure
HaHa
Old 01-29-2008, 10:31 AM   #4 (permalink)
You are right. Water pump seal was leaked badly. Rattling noise came from the T-belt being loose and snapped into half yesterday morning. So, replaced t-belt, water pump, and serpentine belts at the same time. Thanks...
Changing V6 Timing Belt Pics and the $270 Coil Connector marc780 5th & 6th Generation (2002-2006 & 2007-2011) 81 04-09-2012 07:26 AM
DIY V6 Timing Belt Replacement Variety=Spice 1st & 2nd Generation (1983–1986 & 1987-1991) 13 09-02-2009 11:09 PM
Engine wont start... slipped timing belt? PoR2GeEzCamry 1st & 2nd Generation (1983–1986 & 1987-1991) 24 08-12-2007 03:23 PM
timing belt replaced, now 5 deg atdc?? asm Camry & Solara Lounge 5 07-20-2005 04:22 AM
81 Celica and Timing Belt GregAt99 Celica Forum 3 05-10-2003 12:09 PM
