Gen 3.5 Camry V6 Engine Noise - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-28-2008, 06:11 PM   #1 (permalink)
View 95CamryV6GTA's Photo Gallery
3rd Generation Gen 3.5 Camry V6 Engine Noise
Dear all,
My 95 Camry Gen 3 has about 90k on it. Need some help with some peculiar sounds.
1) During each start up,i let it idle, and once the RPM drops to 1.6 i move off.
As the vehicle moves , there is a sound from the right hand side of the engine.
Sounds like a stepper motor i.e a winding sound that last for about 3 seconds.
Does not re-occur again until the next start up.
2) Engine hot, traffic jam. I hear a soft knocking noise. Could it be that the iginition timing is off. I recently changed all the plugs.
Appreciate your thoughts.
Thank you
95CamryV6GTA is offline   Reply With Quote
Old 01-28-2008, 06:59 PM   #2 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
1) prolly a worn belt
2) timing belt. 90K is about teh time it needs to be changed. also change the water pump at teh same time.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 01-28-2008, 07:32 PM   #3 (permalink)
thanx for the reply.
1) Will check the belts
2) Timing belt was replaced about 10k ago.
Old 01-28-2008, 07:41 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
you broke it
well changing the plugs wouldnt cause a timing issue. does the car run and idle ok?
R.I.P.
Car Domain:
Old 01-28-2008, 07:47 PM   #5 (permalink)
car runs like a LEXUS
Honestly, i have been amazed by the way the car is built and run.
I just bought this car about 2 months back.
Timing Belt was done by a Dealer.
Perhaps it's the ignition timing, ... engine knock ?? Need to go buy a timing light and check it out.
Has anyone done this before ?
Old 01-28-2008, 08:24 PM   #6 (permalink)
I HAS BOOST!!!
bigbird's Avatar
people have, a timing gun will tell ya if its off. but unless the dealer didnt get the timing right when they did the timing belt then i cant see how ur timing is off. but if they didnt get it right then u would have noticed this problem immedatly, especially if its running right, bad timing would result in sluggish performance. how well did the previous owner take care of the it? possibly a sticking valve, my old 95 V6 did the same thing but it was around 114k, and thats what it was.
R.I.P.
Car Domain:
Old 01-28-2008, 09:11 PM   #7 (permalink)
Kep
Kep's Avatar
View Kep's Photo Gallery
I'm not sure what a winding sound is or what a stepper motor sounds like. Check for loose belts (I'm not too suspicious of the timing belt since it is relatively new.) What other parts did Toyota replace with the belt? Might be a failing idler pulley.
It wouldn't be a bad idea to do the Sea Foam cleaning routine. Use it through your vacuum system to clean the fuel system. Use it in your gas to clean the injectors and some of the other fuel system parts. Run it in your oil for 100 miles or so before your change your oil. Do a search on this forum and GEN 1&2 forum for "Sea Foam" and "Seafoam" for many discussions and videos on how to do these.
Kep
Old 01-29-2008, 06:41 PM   #8 (permalink)
sure, will give that a try.
Old 01-29-2008, 07:21 PM   #9 (permalink)
How hard can it be?
BlueFusion6851's Avatar
View BlueFusion6851's Photo Gallery
The seafoam through the brake booster line is the ticket to getting a smooth running engine.
BlueFusion6851 is offline   Reply With Quote
