brake bleed question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2008, 01:01 PM   #1 (permalink)
View freeyellow2000's Photo Gallery
*Only changing rear brake shoes on 97 Camry
While I was attempting to take off the rear brake shoes (Left Rear) brake shoe where it set on the wheel cylinder, slide to far to the left and forced the dust boot to come off. The piston as well as some brake fluid leaked out of the wheel cylinder. I know that I must now bleed the brake to remove air but do I need to
a) bleed just the effected wheel cylinder (LR)
b) bleed LR and Right Front (the affected brake lines)
c) bleed all 4 cylinders
Also I was told that I bleed the brake system w/o the use of the jar and the plastic hose attached to the bleeder valve.
freeyellow2000 is offline   Reply With Quote
Old 01-29-2008, 01:38 PM   #2 (permalink)
Dave's
Gameroom cash: $120950
View Dave's's Photo Gallery
If you haven't done anything else, like press the pedal, then you may get away with just doing the left rear. If the master didn't get air into it from low fluid then you're probably ok. If the pedal feels spongy or too low however, I would bleed them all. Don't know why you wouldn't want to use the hose and jar (with some new fluid in it) but it's not absolutely necessary. Just make sure the bleed valve is closed before releasing the pedal. BTW, I'm just an old shade-tree guy so this is JMHO!
Dave's is offline   Reply With Quote
Old 01-29-2008, 01:39 PM   #3 (permalink)
R.I.P. '95 Camry LE V6
Black95Cam's Avatar
View Black95Cam's Photo Gallery
if your gonna bleed the brake system. mind as well do all ov them IMO. better to be safe then sorry, especially when it comes down to brakes. and thats what i use, a plastic/rubber hose and a empty plastic bottle. not really sure why you wouldnt use it because i rather have a place for the fluid to go then have it all over the place.
Originally Posted by Tony the Tiger View Post
The Camry is a car that I can rip out someone's pride, stab it, beat it, and completely bash their egos, and it's so ridiculous that the person comes back with a hysterical laugh... ROFL They got trainlengthed by a Camry that in their mind, was a 18 sec car.
R.I.P. Black95Camry..
Black95Cam is offline   Reply With Quote
Old 01-29-2008, 03:04 PM   #4 (permalink)
If you use the brake pedal bleed technique, and you don't end up with a firm pedal, then try to buy or borrow a manual vacuum pump ... the kind that looks like a pair of pliers.
These usually come with a small bottle and some tubing that you attach to each individual wheel cylinder. Loosen the bleed nut at the wheel cylinder and pump until it looks like there is new or clean brake fluid coming through. This method seems to be a little more efficient at getting all the air out of the brake system, and only requires one person.
... Start bleeding at most distant wheel from the master cylinder ... move towards next closest wheel.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
