Symptoms:
Car started out every once and a while shifting real quick between 3-4 with od, or 2nd-3rd with od off. Also seemed to go to neutral until a certain RPM and would catch. This happened rarly, most other times it was fine.
When put into gear(reverse or forward) trans makes a slight noise until you start moving.
Tranny seems to allow car to over-rev. Adjusting the kickdown cable doesnt seem to make it shift harder(OD shifts hard anyway) as I saw in a guide on these forums.
Now the car:
Starts out in 2nd gear, will down-shifted if pedal floored.
CEL light on, overdrive light blinks when in overdrive.
I expect a tranny rebuild is in order? Unless someone tells me otherwise. Car has 210,000 miles, just bought car with blown engine to put a 40-60K JDM in it, gonna suck pulling it all back out again
. Fluid/filter was just changed.
1994 V6 Camry XLE 1MZ
Also, where the hell do you find sunroof gaskets for these? Is the dealer my only option?
Thanks fellas.
Jonathan
