What are the effects of a bad o2 sensor? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-30-2008, 10:28 AM   #1 (permalink)
View crazyfingers's Photo Gallery
does it effect power and fuel economy in anyway?
i have a 94 v6 xle
crazyfingers is offline   Reply With Quote
Old 01-30-2008, 10:43 AM   #2 (permalink)
Simpsons fan since 89'
Curry's Avatar
View Curry's Photo Gallery
I've heard a bad sensor can affect your fuel economy. Not sure about power.
94' Camry V6 - Sold
96' Lexus SC400 - Crashed by brother
93' Lexus SC300 Turbo - Jackass ran a light and slammed into me
99' GS300 - Sold
02' Subaru WRX Turbo
Curry is offline   Reply With Quote
Old 01-30-2008, 11:42 AM   #3 (permalink)
mixed bag 'o vehicles
ghettosled's Avatar
Gameroom cash: $140095
a check engine light will appear, fuel economy will go down, power will probably decrease as well, engine might not run as smooth...
Old 01-30-2008, 12:17 PM   #4 (permalink)
I HAS BOOST!!!
bigbird's Avatar
Gameroom cash: $549987
iTrader Score: 28 reviews
View bigbird's Photo Gallery
^x2. the car will be running in "limp" mode and will screw with the timing and fule trim. eventually that will screw up your cat converter and ull end up with lots more to fix then just an o2 sensor.
R.I.P.
04 Accord EX-L V6 6m
Car Domain:
Old 01-30-2008, 12:34 PM   #5 (permalink)
Turbo S2000 FTMFW
ECale3's Avatar
iTrader Score: 10 reviews
View ECale3's Photo Gallery
The O2 sensor will affect fuel economy and performance.
The worst part of dying is being alive.
ECale3 is offline   Reply With Quote
Old 01-30-2008, 12:46 PM   #6 (permalink)
Toyota Fan
View toysrvmanager's Photo Gallery
Remember the o2 sensor measures the amount of oxygen in the exhuast to determine how to adjust the air fuel mixture going into the engine. A fualty sensor can trigger the engine to lean out, which causes problems. It can also make it run more rich. This can also damage not only the cat but if left unchecked for an extended amount of time the unburnt fuel will wash down the cylinder walls and wipe out the block.
toysrvmanager is offline   Reply With Quote
Old 01-30-2008, 12:48 PM   #7 (permalink)
Breakin' necks since '02!
Durrby's Avatar
iTrader Score: 12 reviews
View Durrby's Photo Gallery
I don't think it does. Before I replaced mine I was getting about 175-180 miles per tank. After I replaced it I could get over 300. That was the only sign it was bad, crappy mileage.
Bagged 1995 Toyota Camry LE I4 92k
1999 Lexus SC400 153k
Durrby is offline   Reply With Quote
Old 01-30-2008, 01:21 PM   #8 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The CEL will appear only if the O2 sensor itself fails (like not heating to operating temperature on time, response time after ignition timing or fuel volume was adjusted by ecu, strong voltage signal, etc) but in your case it is not responding quickly enough to adjust fuel trim, but still not enough to throw a code. The cat was working properly to not trigger the after cat sensor too!
The lean condition usually usually gets noticed easier with knocking.
Some older O2 sensors (especially 1 wire type) would respond with very bad gas milage and not show fault code, and run in open loop mode.
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-30-2008, 01:33 PM   #9 (permalink)
well i have both of those signs, i have terrible mileage plus the check engine light is on
and my HP is pretty crappy
but i only found out when i took it to get a diagnostics test
btw is there anyway to get those done cheaper than at the mechanic?
i dont wanna spend 70-80 dollars just to find out whats wrong with my car
Old 01-30-2008, 02:07 PM   #10 (permalink)
Darkside Cut Me!!!
Many chain auto parts stores will read the code and reset it free.
I bought a cheap code reader with cancel feature ($40 CDN).
2004 RX330 Sport
2003 Cam I4 XLE
Old 01-30-2008, 02:11 PM   #11 (permalink)
alright thanks, i wanna do another diagnostics test cause with the amount of time that passed from the last time i did a test i think another o2 sensor went out, the mechanic himself was saying the other ones were about to go out and i've recently experienced an even more decrease in power and fuel economy and i just got a tune up
Old 01-30-2008, 04:01 PM   #12 (permalink)
View JalenWu's Photo Gallery
x2, same thing happened...bad gas mileage, then after replacing, kept thinking the gas gauge was broke b/c it didn't go down! No check engine light on my g/f's 93 camry (4cyl).
JalenWu is offline   Reply With Quote
