'92 LE (i4, 5spd) acting weird, keeps unlocking. - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-31-2008, 02:40 PM   #1 (permalink)
View bullycanadian's Photo Gallery
It has power door locks (but not keyloss entry) and it keeps unlocking it self. I was going to dissconnect the negative terminal, but its too cold out side and I'm living on campus at school, so I cleared out anything valuable in the car. Anyone have any idea's as to what this could be?
I'm guessing its obviously electrical, but where do I start looking?
bullycanadian is offline   Reply With Quote
Old 01-31-2008, 03:08 PM   #2 (permalink)
Darkside Cut Me!!!
Gameroom cash: $135123
View Hajoca's Photo Gallery
The doors will not lock if it thinks that the ignition key is still in the ignition lock.
Try some lock deicer in the ignition lock
2004 RX330 Sport
2003 Cam I4 XLE
2000 Cam XLE Gold Edition V6
1998 CamCE I4 Super Commuter!
Old 01-31-2008, 04:09 PM   #3 (permalink)
What do you mean that it does not have keyless entry?
Do you not have the remote keypad?
Or are you positive that the car does not have the wireless unlock feature?
Usually, these cars have the wireless unlock feature, even if you don't have a programmed keypad in your possession. There is a wire ... somewhere in the steering column area under the dash... which might be rubbing against the chassis frame metal someplace. ... This is all that would be required ... grounding out that unlock activation wire .... Not sure, but you might be able to identify the wire, and slide a protective plastic cable ... up under the dash ....and stop the unintentional unlocking.
98 Camry LE, 2.2L, automatic
50k miles, drop in K&N A/F
